Forum: Vue
Subject: Problem with Vue 8.5-9 xstream using 3ds Max
AlexEx opened this issue on Jan 30, 2011 · 5 posts
AlexEx posted Sun, 30 January 2011 at 4:46 AM
The problem is that Vue crashes whenever i trying to render my scene in 3ds Max, containing a few of Max's objects. But if I trying to render a part of the scene, where Max's object is invisible, it works fine. I've started to build my scene using Vue 8.5 and 3ds Max 2011, but at some point this problem appears. I've tried vue 9 then, and my problem is gone. I saved the scene in particular file and continued my work. But few days later i've faced to my problem again. I've tried to render my scene file, saved previously but it still crashes. It's no matter if using either Mental Ray or V-Ray. It's like nightmare. I'm out of ideas. If anybody faced with similar problem, please help me.
hobepaintball posted Sun, 30 January 2011 at 11:19 AM
I use 9 INF so Vue and 3ds max work independantly. Have you tried a VERY simple pair of scenes? Very high res terains etc could be a problem.
AlexEx posted Tue, 01 February 2011 at 11:58 AM
I've tried, it renders fine. Indeed, it seems like Vue don't suite for using it's large terrains in Max. But it still vry weird that Vue crashes now when I try to render scene, wich was rendered perfectly some time before.
surveyman posted Tue, 01 February 2011 at 7:11 PM
Can you report on memory utilization?   ie... Are you running out of memory?
AlexEx posted Fri, 04 February 2011 at 2:09 AM
No, I'm not. I have 8 GB RAM and when rendering it is used only 4 GB of them
