moonwatcher opened this issue on Feb 10, 2011 · 4 posts
moonwatcher posted Thu, 10 February 2011 at 4:53 PM
bagginsbill posted Thu, 10 February 2011 at 5:13 PM
Because you also have 100% diffuse (clear as clay) reflection. Set Diffuse_Value = 0
Also, ALWAYS ALWAYS ALWAYS disable Reflect_Lite_Mult and Reflect_Kd_Mult
SamTherapy posted Thu, 10 February 2011 at 5:15 PM
First thing, get rid of Reflect_Lite_Mult and Reflect_Kd_Mult, which do nothing in this case, except slow down and degrade your render. I don't know of any situation when they should be used but maybe there is one.
Next - and I don't know the best way to explain this - nothing in the real world is 100% diffuse colour, 100% transparent and 100% reflective. You'll never get realistic (or even good) results with those settings. As I understand it (which is, admittedly, not well) the transparency and reflection settings will be fighting with each other and also with the Diffuse setting.
Also, don't use Auto settings, they are by and large, crap. Nobody needs 6 Raytrace bounces, for example.
I'm certain another person here can give a better explanation and an example or two but at least you have a start on things.
SamTherapy posted Thu, 10 February 2011 at 5:16 PM
