Subject: V4 eyes
drkfetyshnyghts opened this issue on Feb 12, 2011 · 6 posts
drkfetyshnyghts posted Sat, 12 February 2011 at 7:56 AM
Hey guys how do you get poser models to look at / follow the camera? I'm sure this is simple and I am pretty sure I used to to do it P7.... but cant figure it out in Poser Pro 2010
HELP!
Cariad posted Sat, 12 February 2011 at 8:19 AM
I know for P8 it is. select the eye then Object>Point At> select the camera or whatever else you want it to follow.  Rinse and repeat for the other eye.
Don't use PP2010 yet.
hborre posted Sat, 12 February 2011 at 8:23 AM
Same difference for PP2010.  That has not changed through all the recent versions.
drkfetyshnyghts posted Sat, 12 February 2011 at 1:55 PM
Thanks guys.. just needed a nod in the right direction. That'll teach me for not usng Poser half enough.
wolfie posted Mon, 14 February 2011 at 1:05 PM
I have gotten in the habit of adding a sphere to the scene and set it so that its not visible in the raytrace scene.  I then point the eyes to that and parent the sphere to the aux camera (which I use to render, I use the main for posing etc).  That way I can use the sphere to pont the eyes off camera or directly at it and if you move the camera, they will track with it.  If I have multiple characters in the scene, I name and colorize the spheres so its easy to distinguish them when creating the poses.   You can also use a similar technique on the head as well to make the head track with the camera or off to one side of it.  For head tracking I usually use a box instead of the sphere and then point the head at the box, the eyes at a sphere.  The box gets parented to the camera, the sphere to the box.  You can then detach the box from the camera if you want and the eyes will stay relative to the head.
The heirarchy window stays open for me most of the time :)
hborre posted Mon, 14 February 2011 at 1:22 PM
An excellent tip, wolfie.  I will definitely keep this in mind next time I need to track a camera.
