diomede opened this issue on Feb 19, 2011 · 6 posts
diomede posted Sat, 19 February 2011 at 9:26 AM
I installed vicki 4 and the related DAZ figures, Girl 4, Stephanie 4, She Freek 4, Aiko 4. However, when I attempt to load the related figures and morph injections, like the Girl 4, poser is not recognizing the morphs. Just as a check on my install, I added my Daz Content "runtime" to my Carrara contnent browser. Carrara is able to properly load the figures and morphs.
Something is up, but I can't figure out what.
I've tried to attach pictures. One is from loading the Girl 4 in poser and the other is carrara. You can see that Poser is just Vicki 4, but Carrara recognizes The Girl 4.
Any idea what the problem is, and what the solution might be? I've already tried reinstalling The Girl 4.
diomede posted Sat, 19 February 2011 at 9:27 AM
diomede posted Sat, 19 February 2011 at 9:28 AM
pjz99 posted Sat, 19 February 2011 at 9:45 AM
Make sure you re-run the "Update V4" utility? Is it all installed to the same runtime? Is the runtime the Poser default runtime?
diomede posted Sat, 19 February 2011 at 9:58 AM
I re-ran the update v4 utility. Poser still doesn't recognize the girl 4 morphs.
I have a separate runtime called DAZ Content. That is where I install everything I get from DAZ. Until now, everything worked fine. I did that because of UAC issues, which has been discussed at length in by other posters. This runtime setup could be the issue, but the "Morphs ++" injection works fine and it is placed in the same runtime.
It would be a lot easier to diagnose if nothing worked or everything worked. It is very odd that some DAZ morph injections in Poser are working and some are not. It is even more odd that the morph injections that don't work in Poser are working in Carrara.
Aaargh.
pjz99 posted Sat, 19 February 2011 at 2:02 PM
Probably best you contact DAZ support:
TOLL FREE: 1(800)267-5170 | Phone: 1(801)495-1777
