Subject: Poser Polygon Count
Cybertenko opened this issue on Feb 25, 2011 · 8 posts
Cybertenko posted Fri, 25 February 2011 at 11:22 AM
Is inside of poser somewhere information about polygoun count of the scene?
jonnybode posted Fri, 25 February 2011 at 12:36 PM
Hi!
There is a python script called "printGeomStats" that will do the trick, it resides in folder "Printinfo".
Medzinatar posted Fri, 25 February 2011 at 12:40 PM
Top Bar "Scripts-->PrintInfo-->printGeomStats"
Cybertenko posted Fri, 25 February 2011 at 1:20 PM
thank you, can somehow be shown total polygon count? I am getting info about each object only.
geep posted Fri, 25 February 2011 at 2:53 PM
  1. Export all objects
  2. Import (Exported) object
  3. Run script on imported object
cheers,
dr geep ... :o]
edited 10/5/2019
Cybertenko posted Fri, 25 February 2011 at 3:05 PM
a little bit complicated but i will try that. thank you.
RobynsVeil posted Fri, 25 February 2011 at 4:59 PM
Or, you can just add the results of printGeomStats? :biggrin:
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
KageRyu posted Sun, 27 February 2011 at 2:58 AM
I believe the Advanced Render Settings from RDNA/Semideui will give the information you seek in it's main settings window.  It has a lot of other handy and useful abilities too - I consider it a must have.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
