attileus opened this issue on Mar 02, 2011 · 6 posts
attileus posted Wed, 02 March 2011 at 9:17 AM
Hi guys!
I was thinking about to render some biomechs - lol - but I'm not sure how to get wires/cables into Vue. I usually model objects in Wings but I'm looking for an easier way to get especially cables.
In my latest pic I used resized cylinders to make thick cables so I could do that but I'm not totally satisfied; it consumed much memory using hundreds of primitives. (cylinders)
In Bryce someone made 300 metaballs and linked them to a movie track/time line - lol - and it worked perfectly as a movable cable...I'm just looking for similar solutions if you have any...or suggestions about a cheap software that can make cables in an easy way; thanks!
JCD posted Wed, 02 March 2011 at 8:47 PM
That is one area where Vue is lacking an in-program solution. You can make them from lots of little cylinders, but that's a bit of a PITA and not exactly very efficient. That said, I've made most all of mine in Modo as it's pretty quick and easy to whip up some cable forms and then export them as .obj files.
At one point I had a freebie set of cables as ready to use .vob files - not that it helps you make them, but I can dig those up if there is any interest :)
attileus posted Thu, 03 March 2011 at 1:32 AM
Quote - That is one area where Vue is lacking an in-program solution. You can make them from lots of little cylinders, but that's a bit of a PITA and not exactly very efficient. That said, I've made most all of mine in Modo as it's pretty quick and easy to whip up some cable forms and then export them as .obj files.
Thanks JCD...I would like to take a look at those cables you got and will check out Modo.
JCD posted Thu, 03 March 2011 at 11:09 PM
Ok, I dug them up and tossed them on the server. I'm slowly migrating my site from one place to the other, so much of this stuff is still MIA and the site is a bit of a mess. Nonetheless, you can snag the pack of ten cables from here.
Enjoy!
attileus posted Fri, 04 March 2011 at 3:21 AM
Many thanks JCD; I downloaded the cables and will use them.
I also tested Modo and indeed it's a great programme, I could make a cable in a few seconds...just wish Vue had a similar plug-in.
Thanks again!
silverblade33 posted Fri, 04 March 2011 at 4:30 PM
yeah metaballs works, time consuming but do-able :)
I made custom rope texture, easy to change colour to make it rust, thinks its freebie on my site
otherwise I use Rhino, as it's NURBS I can model very complex ropes etc ;)
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
