airflamesred opened this issue on Mar 04, 2011 · 5 posts
airflamesred posted Fri, 04 March 2011 at 2:29 PM
Hi there
Running through the gus tut and stumbled on page 1. Whats the key for rect select - I can only get lasso and that won't finish the select - it just fades out like a candle in the wind. 2.49 xp pro
thanks
benney posted Fri, 04 March 2011 at 2:50 PM
To get the border select (rect select) just hit the "B" key.
Hope it helps
airflamesred posted Sat, 05 March 2011 at 7:49 AM
Thanks benney got it. I'm now wondering why, having deleted half the cube, there is a stray vert in the centre of the cube?
benney posted Sat, 05 March 2011 at 10:46 AM
Ah.. That is because blender is one of the few programs that can extrude vertices to create edges and so forth.. It happens.
Aardvark_ posted Sat, 05 March 2011 at 4:39 PM
Quote - Thanks benney got it. I'm now wondering why, having deleted half the cube, there is a stray vert in the centre of the cube?
It may not be a vertex. It may be the origin for the object. If one deletes all the vertices on an object, the origin will still remain. It's orange, and so can look like a vertex. A cube's origin, unless the cube's vertices are moved in edit mode, is in the center of the cube.
