Subject: ERC controlled by other figure ? or figure conform to?
midnight_stories opened this issue on Mar 19, 2011 · 9 posts
midnight_stories posted Sat, 19 March 2011 at 9:49 AM
OK this is another tricky one, you guys amazed my last time!
This may not be possible in poser but it works in DS.
I’ve created a  Morph for the Left thigh and I want to drive it with the side-side or Zrot rotation of the figure it’s conformed to using it’s Left Thigh, Zrot. I actually used easypose to do it but had no luck here’s the code below.
targetGeom L-Thigh-Side-Side
                                                name L-Thigh-Side-Side
                                                initValue 0
                                                hidden 0
                                                forceLimits 1
                                                min -100000
                                                max 100000
                                                trackingScale 0.02
                                                keys
        static  0
        k  0  0
                                                interpStyleLocked 0
                                                valueOpDeltaAdd
        conformingTarget
        lThigh:1
        zrot
                                                deltaAddDelta -14.000000
                                                valueOpDeltaAdd
        Figure 1
        BODY:1
        L-Thigh-Side-Side
                                                deltaAddDelta 1.000000
                                                indexes 501
                                                numbDeltas 4363
                                                deltas
I know I will have to set
                forceLimits 1
                                                min 0
                                                max 1
But not sure what
conformingTarget
is  ?
conformingTarget BODY:4
was in the “secret of figure creation with poser 5” book but could find what the options were. I tried this but no good. Any ideas or point me to a tutorial for it.
Thanks in advance
Midnight
Dead_Reckoning posted Sat, 19 March 2011 at 10:20 AM
Have you tried using "Dependant Parameters"?
Semiedieu gives a short tutorial here.
http://tutorials.shaderworks-studio.com/DP_ArmLength/index.html
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
midnight_stories posted Sat, 19 March 2011 at 11:02 AM
That's quite a good tutorial Thanks I picked something up there, but this has to work in poser 7 as it's being tested by DAZ. I'm trying to do what they have with their bodysuit.
Cage posted Sat, 19 March 2011 at 11:29 AM
You can set up a conforming figure to "super-conform" (slave ERC to the conforming parent) by stripping the figure numbers from the ERC listings in the conformer .cr2, then saving it to the library.
Quote - valueOpDeltaAdd
Figure
BODY
L-Thigh-Side-Side
When loaded into the scene, the conformer ERC will automatically point toward whichever figure is currently selected.  So select the conforming parent figure, load the conformer, then conform it.  The ERC should super-conform.
midnight_stories posted Sat, 19 March 2011 at 11:39 AM
Excellent idea my friend I think you have it !!!
SO a big thanks :)
msg24_7 posted Sat, 19 March 2011 at 12:16 PM
Quote - That's quite a good tutorial Thanks I picked something up there, but this has to work in poser 7 as it's being tested by DAZ. I'm trying to do what they have with their bodysuit.
Dependent parameters do work in Poser 7.
They have been available since then, but you had to do them by hand using a text editor.
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
markschum posted Sat, 19 March 2011 at 3:45 PM
Some of the items done with dependant paraneters in P8 screw up badly in Poser 7 sr2.  I converted a couple of freestuff items to work in Poser 5,6,7.
lesbentley posted Sat, 19 March 2011 at 7:32 PM
Delete all this:
            valueOpDeltaAdd
                conformingTarget
                lThigh:1
                zrot
                valueOpDeltaAdd
                Figure 1
                BODY:1
                L-Thigh-Side-Side
Replace it with this:
            valueOpDeltaAdd
                Figure
                lThigh
                zrot
Before you load the conformer, make sure some part of the character figure is selected.
midnight_stories posted Sat, 19 March 2011 at 10:34 PM
Quote - Delete all this:
            valueOpDeltaAdd
                conformingTarget
                lThigh:1
                zrot
                valueOpDeltaAdd
                Figure 1
                BODY:1
                L-Thigh-Side-Side
            valueOpDeltaAdd
                Figure
                lThigh
                zrot
Yes I got it in the end very similar but just one change to your code where Figure is you put the actual name of the figure and it works great.  Thanks for the Tip !!!
