Forum: Vue
Subject: render errors
perilous7 opened this issue on Mar 19, 2011 · 7 posts
perilous7 posted Sat, 19 March 2011 at 3:02 PM
Hi all,
Am getting render errors it seems to be black squares on reflective materials, as i tried resetting the offending material and that cured it, question is,WHAT is causing it and how to do i deal with it?
Am trying to upload a pic but the site is playing up doh :-(
 A cleaved head no longer plots.
http://www.perilous7.moonfruit.com
ShawnDriscoll posted Sun, 20 March 2011 at 7:14 AM
What version and build are you using?  And what OS?
perilous7 posted Sun, 20 March 2011 at 12:54 PM
windows 7 64bit and vue 9. i got it running on my pc and my laptop both produce the same results
perilous7 posted Tue, 22 March 2011 at 5:25 PM
pic finally
Cear posted Mon, 25 April 2011 at 8:19 PM
never got a fix for this huh? Driving me nuts. its happening on every picture i make with foamy water. only on superior or higher settings.
ShawnDriscoll posted Mon, 25 April 2011 at 10:14 PM
It depends on what you're reflecting, and what your material settings are.  Hard to find an exact fix without a posted image of the entire scene.
bigbraader posted Tue, 26 April 2011 at 4:21 AM
Sometimes you can make them go away by changing the antialiasing method to "Crisp". I used to get them a lot, but since I've isolated and removed the objects/materials that caused them it doesn't happen anymore.
Also I've only had them when rendering with radiosity.
