Subject: Objects not rendering on the inside.
Fremmen opened this issue on Mar 19, 2011 · 7 posts
Fremmen posted Sat, 19 March 2011 at 8:46 PM
Hello
I every once and awhile run into a problem where I render a picture and the inside of a cloth figure or a prop hair is for lack of better terms empty. For example I rendered a picture  from a forward view with a hair prop,  and between the right side of her face and hair that is next to it it came out just a white space(the back ground was white). The hair prop goes down to the neck. When I rendered it from the right side profile the hair is all the way down to  the neck of the person. Another time I rendered a picture from the front, of a hood on a figure, the inside of the hood next to the persons head was see-thru. Again from any view of the outside of the hood it is fine. Does anyone know what might be causing this. Thanks for any help in advance.
Simon
Medzinatar posted Sat, 19 March 2011 at 8:53 PM
select "Normals Forward" on material, that way they will face the camera
Fremmen posted Sat, 19 March 2011 at 9:29 PM
Thanks
 I will try that.
estherau posted Sun, 20 March 2011 at 1:30 AM
if you render with gamma make sure it is off for all your hair transmaps.
Love esther
MY ONLINE COMIC IS NOW LIVE
estherau posted Sun, 20 March 2011 at 1:54 AM
nice!
estherau posted Sun, 20 March 2011 at 2:10 AM
that last post was in the wrong thread.  sorry.
lesbentley posted Sun, 20 March 2011 at 10:50 AM
Quote - I every once and awhile run into a problem where I render a picture and the inside of a cloth figure or a prop hair is for lack of better terms empty.
In your Render Settings, make sure "Remove backfacing polys" is turned off.
