Forum: Poser Technical
Subject: XYZ Texture Animated Motion
KageRyu opened this issue on Mar 21, 2011 · 14 posts
KageRyu posted Mon, 21 March 2011 at 12:29 AM
OK, I am using Poser Pro 7, and I want to animate a texture on the XYZ coordinates (Procedural Texture that is).  It seems reasonable this should be acomplishable, but I see no where to enter in a reference point for the textures center point.  I'm thinking maybe it has something to do with the P Variable Node but have not gotten the desired results so far.  I can find nothing in the manual, or on the SM tutorial pages, or other tutorial sites, to accomplish this.  Does anyone have any suggestions?
This is such a simple task in other software...however I want to finish the scene entirely in Poser if posible, to avoid massive amounts of time retexturing, and later post production work.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
