MikeMoss opened this issue on Mar 21, 2011 ยท 6 posts
MikeMoss posted Mon, 21 March 2011 at 11:51 AM
Hi
When I do a long video I always have to make sure that the last frame of one clip matches the first frame of the next.
I do this by saving the first completed clip then saving it again under a new name i.e. myfilm clip 02, etc. then I move that clip to the start of the video and delete the rest of the frames. I create the next sequence starting from there.
But sometimes something gets changed and when I'm done working on it the frames don't match exactly.
I have a situation like that right now.
I have a lead in sequence that's about 300 frames leading into a 3400 frame sequence that has lip syc etc.
Some how the expression of the figure doesn't exactly match up now that i'm finshed with both of the clips. Probebly because of the lip syncing with Mimic.
Now my question...
Is there some way that I can save the frame from the start of clip 1 and move it to the end of clip 2 so that the clips will match exactly?
I haven't been able to figure out a way to do this.
Mike
If you shoot a mime, do you need a silencer?
