Subject: Anyone up for some benchmarking?
onnetz opened this issue on Mar 21, 2011 · 36 posts
onnetz posted Mon, 21 March 2011 at 2:40 PM
I haven't seen this done in a while and would like to compare my rig to some of the others out there.
I'm using Pro 2010 and would like it to be open to any version of poser.
Maybe a scene file using IDL and one without so older versions of Poser can participate. I'm also trying to think of a way to test Posers use of memory as well. Not just the cpu. I know from what I remember other benchmarks have just measured time. What I would like to do is also get hardware stats like  temps.
 If enough people seem interested we can work out the details of a scene and settings. If not then I will set up a scene along with settings myself and post my results. Making it available to others.
Not everyone knows exactly what they have as far as their system goes so here is a link to a program that tells all. No installation needed. Just unzip it.
cpu-z 1.57
Here's a program to read all your temps along with fan speeds and a couple other things from your hardware.
 HWMonitor 1.17
Both links go to http://www.cpuid.com
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
MagnusGreel posted Mon, 21 March 2011 at 2:45 PM
I have my hammer chisel and spray ca....oh. not that kind of benchmarking...
Airport security is a burden we must all shoulder. Do your part, and please grope yourself in advance.
onnetz posted Mon, 21 March 2011 at 2:51 PM
Well I'm hoping to chisel out a scene that will do the hammering. :-)
parkdalegardener posted Mon, 21 March 2011 at 4:31 PM
With the age of this system I'd be too embarassed to post the results.
onnetz posted Mon, 21 March 2011 at 5:39 PM
Nothing to be embarassed about, its all about the comparisons. So the wider range of systems the better.
Got a scene setup and am working on different settings right now. These settings were a bit high and took about 17mins to render at this resolution. Gonna drop the settings a bit, hoping to keep high under 10mins on my system. I will have settings for low,med, and high.
Idl and raytracing in this scene. The only light is a hdri mapped to a plane in the ceiling.
parkdalegardener posted Tue, 22 March 2011 at 9:46 AM
I've subscribed to the thread so I'll keep my eyes open for the test scene
onnetz posted Tue, 22 March 2011 at 11:28 AM
Just got done with the low, medium, and high settings for IDL and raytracing.
The file can be downloaded from my file locker.
Intel Core2 Quad Q6600 @ 3.6ghz
Low: 57s
Medium: 3m20s
High: 8m05s
Max temps for cores
Core 0: 58c
Core 1: 59c
Core 2: 52c
Core 3: 55c
onnetz posted Tue, 22 March 2011 at 2:01 PM
Just uploaded a scene using only AO and Raytracing. I should add that I saved all these scenes running Pro 2010. I'm not sure how backwards compatibilty is with opening them in older versions of Poser.
I should also add that I'm running win 7 32 bit with 4x1 gigs of memory.
My time for this one:
AORaytrace: 2m43s
parkdalegardener posted Tue, 22 March 2011 at 2:46 PM
Downloading now. I'll deal with it later this evening. My Federal Govt. is just about to bring out the budget and that could provide a few more fireworks than firefly
onnetz posted Tue, 22 March 2011 at 5:22 PM
Quote - Downloading now. I'll deal with it later this evening. My Federal Govt. is just about to bring out the budget and that could provide a few more fireworks than firefly
Great. I'm looking forward to your results.
To everyone: Running this test isn't just for bragging rights on who has the fastest computer. Think of it as a form of maintenance or preventive maintenance if you will.. Running the test gives you a snapshot of your systems performance relative to poser. This is why I recommended running the hardware monitors as well. Maybe your system is running hotter than it should. Or you see similiar systems to yours running the benchmark much faster. Or maybe you run the test a month or two from now and your numbers dont match up to previous runs. It gives you a heads up that somthing might not be right with your system.
Getting a bit anal about things but somthing I do before running any benchmark is to check the taskmanager for what processes are running looking for anything out of the ordinary or things that really dont need to be running.
Before running the tests today on win 7 I had 47 processes running.
parkdalegardener posted Tue, 22 March 2011 at 7:36 PM
Just the numbers. I only have a few minutes before I have to go out.
System: E5200 Dual core Pentium LGA775 @ 2.5 800FSB
Memory: 1 piece 2GB DDR2 800
Free ram before running Poser: I'll get back to you on this with the exact number but 256 meg goes to the onboard graphics and the is always AVG running in the background.
All tests done seperately on a clean boot with the above overhead.
Poser 8 SR3 on  Win 7 32 bit
IDL Benchmark Test
Low:       1min 58.901 sec
Medium: 6min 35.724 sec
High:      15min 39.227 sec
Gotta go. I'll post the AO test settings when I get a sec tomorrow morning.
ws99pf posted Tue, 22 March 2011 at 8:39 PM
Intel i7 860 2.80 GHz
8GB RAM
Windows 7
Poser Pro 2010
Low: 24s
Medium: 1m16s
High: 2m59s
Max temps for cores
Core 0: 54c
Core 1: 52c
Core 2: 53c
Core 3: 51c
Miss Nancy posted Tue, 22 March 2011 at 9:19 PM
mac users: smcFanControl.app.
onnetz posted Tue, 22 March 2011 at 9:51 PM
parkdalegardener: Thanks for posting your results. The E5200 is a great chip. overclocks like crazy.
ws99pf : Hyperthreading was on I'm assuming. Those are some awesome times and I was feeling good about my times. Time for an upgrade. :-) Imagine what times you would get with that chip at 4ghz. With those temps you've got a little headroom for overclocking if your into that.
Miss Nancy: Thanks, didn't mean to leave the macs out.
parkdalegardener posted Wed, 23 March 2011 at 9:42 AM
Here's the AO test number. Same conditions as before. Clean boot. System overhead on clean boot is 800 meg leaving 1.2 gig physical ram available before fireing up Poser. That was the number I didn't have on hand last night. And the result is.....
6 min 41.251 sec
12rounds posted Thu, 24 March 2011 at 10:53 AM
System:
Memory: 6 gigs
Operating System: Ubuntu Linux 10.10 (64-bit)
Processor: Intel Core i7 920 @ 2.67Ghz (Quad Core with hyperthreading)
Windows version of Poser 8 running on Wine binary compatibility layer
Stats:
AO Test: 1min 48 seconds
IDL test (Low): 33 seconds
IDL test (Medium): 1min 59 sec
onnetz posted Thu, 24 March 2011 at 5:14 PM
I wonder how much of an impact wine has on performance. I would think the 920 would be a bit closer to the 860 .
Gazukull posted Thu, 24 March 2011 at 6:06 PM
Quote - I wonder how much of an impact wine has on performance. I would think the 920 would be a bit closer to the 860 .
While I have no bench numbers on me, I used to run p8 under wine (ubuntu 9.10) and performance to be poor.  It seemed to exhibit poor cpu usage while running renders (watching system monitor).
I am going to attempt to get my w7 x64 numbers up when I get home.
-G
12rounds posted Fri, 25 March 2011 at 2:37 AM
Actually I watched the CPU performance while rendering. Utilisation of all 8 CPU threads was full at all times.
I have found P8 to run very good and fast on my system (in fact so did Poser 7 earlier) and have done so for years.
It is not wise to make performance judgements comparing rendering times between Poser 8 and Poser Pro 2010 - their rendering times are surely not the same no matter what the underlying operating system.
Gazukull posted Fri, 25 March 2011 at 12:40 PM
Quote - Actually I watched the CPU performance while rendering. Utilisation of all 8 CPU threads was full at all times.
Totally agree.  When I ran the same render in both for FYI purposes, the 2010 x64 cut off like 56 seconds on a complex scene vs p8.  When animating, that added up real quick.
ws99pf posted Fri, 25 March 2011 at 3:00 PM
Quote - ws99pf : Hyperthreading was on I'm assuming. Those are some awesome times and I was feeling good about my times. Time for an upgrade. :-) Imagine what times you would get with that chip at 4ghz. With those temps you've got a little headroom for overclocking if your into that.
Yes, hyperthreading with 8 threads. I should have mentioned that the i7 860 was slightly overclocked to 3.1 GHz
Over the next few weeks I'll be building a new box with the second generation i7 2600k 3.4GHz, so I'll publish the results when I get them, together with improvements from overclocking.
I think using a SATA6 SSD for the runtimes and temp files should result in slightly fast renders too.
12rounds posted Sat, 26 March 2011 at 2:58 AM
"I think using a SATA6 SSD for the runtimes and temp files should result in slightly fast renders too."
I used to run P8 from a SSD a couple of years back, but didn't get the overall boost I had hoped for so I switched the SSD to better use (systems disk) and Poser Runtime is in a 10000rpm traditional disk. The most obvious gain in my experience was when reading big save files (with "big" I mean files in the size range of over 300 megs) and the pre-rendering texture-reading phase. There might've been slight increases in other areas, but I never bothered to time anything precisely. I have SSDs on 4 computers as systems disks and will never ever go back to traditional disks in that area again.
A little OT, but last year I put together a machine for my daughter from spare parts and one cheap-o Kingston 128GB SSD and wow ... that baby boots up to full operating system (Ubuntu Linux) with full graphics environment and networking set in only 8 seconds! Same thing with my mini-laptop (Asus EEE) from which I switched the disk to a high-performance SSD.
ws99pf posted Sun, 03 April 2011 at 2:13 PM
Here are the benchmarks for the i7 2600k I promissed...
16GB RAM
Windows 7
Poser Pro 2010
Stock speed 3.40GHz
Low: 19s
Medium: 1m
High: 2m24s
Max temps for cores
Core 0: 51c
Core 1: 55c
Core 2: 56c
Core 3: 55c
Overclocked to 4.40GHz
Low: 16s
Medium: 52s
High: 2m07s
Max temps for cores
Core 0: 56c
Core 1: 62c
Core 2: 63c
Core 3: 61c
If 4.4 is stable I might try to go a bit higher.
onnetz posted Sun, 03 April 2011 at 2:58 PM
Thanks for the results. I definitely need to upgrade. :-)
What motherboard are you using? 16gb of ram will probably lower your max stable overclock.
ws99pf posted Sun, 03 April 2011 at 9:35 PM
The motherboard is the ASUS Sabertooth P67.
FYI the RAM is 4x Corsair Vengeance 4GB speed 1600
I didn't know that about the RAM.
onnetz posted Sun, 03 April 2011 at 11:20 PM
Here's some good info for that motherboard and a couple others from ASUS..
http://www.overclock.net/intel-motherboards/910402-asus-p67-series-information-thread-drivers.html
232bird posted Mon, 04 April 2011 at 10:29 AM
Maybe I should bring AMD into the mix :)
Athlon II X4 630 OC'ed to 3.6 GHz
8 Gb of DDR-3
Windows 7 x64
Poser Pro 2010
Low: 51s @49c
Med: 2m17s @51c
High: 5m21s @52c
I'll admit I was apprehensive about doing this with a budget processor, but considering the CPU only cost me $95 (a year ago, at a retail store even), I think I couldn't be happier with the results.
onnetz posted Tue, 05 April 2011 at 12:29 AM
Nice numbers and thats a good deal. I paid $100 used for my Q6600.
I'm sure that DDR3 helps a bit too. what speed is it?
JimTS posted Tue, 05 April 2011 at 1:00 AM
I'm a little lost can't find where to DL the file to even try
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
onnetz posted Tue, 05 April 2011 at 9:53 AM
Quote - I'm a little lost can't find where to DL the file to even try
Click onto my homepage and go to artist input. From there you can find my file locker.
The file your looking for is "IDL Raytrace Benchmark".
232bird posted Tue, 05 April 2011 at 11:47 AM
Quote - Nice numbers and thats a good deal. I paid $100 used for my Q6600.
I can't for the life of me remember what speed it is, 10666 or 13333.  Regardless, I have it running at 1460 MHz since I had to crank the CPU frequency up so high (locked multiplier). Since the RAM freq is lower than stock I decreased my latency timings to compensate.  I'm using the OCZ memory and it is junk, won't go over 1600 MHz for anything and I think it is not very stable.
I am VERY surprised I was able to beat your times, since we are clock-for-clock.  The Q6600 was a better CPU than mine IMO, it was the competitor to the Phenom IIs.  What do your RAM settings look like?  Even at DDR2 I would think that wouldn't make a big enough difference since the scene was small.  Also, I don't know what your bus frequencies are, but it may help to raise those, then lower your CPU multiplier to compensate if 3.6 is your upper limit. Sorry I can't better explain what I'm talking about, I don't have as much experience overclocking Intels as I do AMD.
onnetz posted Wed, 06 April 2011 at 2:36 PM
You can use the cpu-z program I posted a link to and find out what your memory is running at. It works for intel and amd.
I'm running a 1:1 ratio on the bus and memory.  400 on the bus and 800 on the memory. Timings are pretty loose at 5:5:5:15. I was running it at 1066 with the same timings but got intermittent crashes about once a month. Tried 5:5:5:18 and still wasnt stable.  My multiplier is set at 9. The memory is rated at 4:4:4:12 800mhz.
I'm using the p5q pro turbo motherboard and for quads it doesnt like to go over 460 on the bus.
Tomorrow I will get the q6600 up to 4ghz and tighten the timings for the memory, then run the benchmark. I've had it up to 4.1ghz but vcore was getting kindof high along with temps. I'm using the cm v6gt for cooling but it still likes to run hot
Remember the Q6600 is the older 65nm technology instead of the 45nm for newer 775 socket cpus.
232bird posted Thu, 07 April 2011 at 12:30 AM
Quote - You can use the cpu-z program I posted a link to and find out what your memory is running at. It works for intel and amd.
 My DRAM Freq is 680 MHz, with a 3:8 multi (255 MHz Frontside bus).  Timings are 7:7:7:24, but DDR3 doesn't have as good a latency as DDR2.
Quote - I'm using the p5q pro turbo motherboard and for quads it doesnt like to go over 460 on the bus.
Mine gets cranky over 260.  And yet somehow I had it running at 275 for a few weeks just fine, I just can't remember now how I did it lol.
Quote - Tomorrow I will get the q6600 up to 4ghz and tighten the timings for the memory, then run the benchmark. I've had it up to 4.1ghz but vcore was getting kindof high along with temps. I'm using the cm v6gt for cooling but it still likes to run hot
For some reason I was thinking mine was 65nm too, but it's 45nm.  Maybe that's the difference.
JimTS posted Thu, 07 April 2011 at 3:52 AM
Thanks much
High 5m 32s
temps core 0 58c
          core 1 58c
          core 2 63
          core 3 64
all!!!max!!!! oy
Med 2m 15s
temps marginally Lower 2-3c
Low    43s
temps Lower still -2c
I don't think the ARCTIC COOLING Freezer 7 Pro Rev.2 92mm is making it
Config Q9550 2.83 timing
4x2 GB G Skill Ram F2-8500CL5-2GBTD
Charles Péguy
onnetz posted Thu, 07 April 2011 at 11:30 AM
Quote - Thanks much
High 5m 32s
temps core 0 58c
          core 1 58c
          core 2 63
          core 3 64
all!!!max!!!! oy
Med 2m 15s
Low    43s
Yeah, you really need a 120mm heatsink on that Q9550. What kind of case do you have? If room is a problem you can get a used H50 for cheap these days.
moriador posted Fri, 08 April 2011 at 3:31 AM
Since we've started a discussion on the other thread about rendering, I was curious to know how my machine would do. I figured I'd post results of your benchmarks here.
Win7 Home Premium 64, Poser 8
Intel(R) Core(TM) i7 CPU  860  @ 2.80GHz
Gateway FX6840
12288 MBytes DDR3
Radeon HD 5770
AO: 1:57
IDL Low: 41
Med: 1:50
High: 4:11
