magnemoe opened this issue on Apr 01, 2011 · 3 posts
magnemoe posted Fri, 01 April 2011 at 9:04 AM
Have a problem here I’m sure it’s a simple solution to. The default Stephanie 4 figure is shorter than Victoria 4 so to get conforming clothes to fit you parent the cloth to Stephanie 4 and then conform, this work perfect for everything except hair that usually end up to low if parented and conformed but to high if just conforming.
Resizing the hair body sometimes work but usually the joints get wrong.
Any tips to solve this? Best would be a fit pose, but I can not find anything.
Medzinatar posted Fri, 01 April 2011 at 9:29 AM
select body and under properties check box "include scales when conforming"
This usually solves problem for both Stephanie 4 and Reby Sky
magnemoe posted Fri, 01 April 2011 at 12:31 PM
Thank you it worked perfectly.
