hobepaintball opened this issue on Apr 26, 2011 · 6 posts
hobepaintball posted Tue, 26 April 2011 at 5:17 AM
Through a series of misteps I have a complex scene set up, but at frame 30 not frame 1. I want to save just this frame and delete 1-29. There are no hair or cloth simulations at this point, so they wont be a problem. Saving just frame 1 is easy but for some reason, even after all these years I don't know how to do the reverse.
millighost posted Tue, 26 April 2011 at 5:57 AM
I do not know how to save only a specific frame of an animation without deleting frames, so perhaps you already know more than me. But this is what i would do: simply copy frame 30 to frame 1 in the keyframe editor and then delete keyframes 2-30. The effect would be the same, wouldnt it?
hobepaintball posted Tue, 26 April 2011 at 6:27 AM
My issue is most of the many many props and furniure items were added at frame 30 so its all the "stuff" I am trying to save. So now that the room is built, the lighting is set and the models are posed I want to save frame 30 as a launching point for the project.
As for deleting frames AFTER what you want to save that is simple. Lets say you want to save frames 1-20 of 30. Just go to frame 20 and in the "frame of counter" enter 20 instead of 30. Poser will notify you you are deleting frames and you are set.
dadt posted Tue, 26 April 2011 at 7:18 AM
I would go to frame 30 then use Edit/Memorise/All.
Then go to frame1 and Edit/Restore/All
You will then have your scene in the first frame.
ockham posted Tue, 26 April 2011 at 7:22 AM
Ditto dadt. I use that method all the time when I've accidentally added something new at a later frame.
Or if you don't want to mess up the rest of the animation: Memorize only the new item, go back to 1, restore the new item.
It would be nice if Poser had a warning or a stopper when you try to add something after 1. There's no proper reason to do that; it's always an accident.
hobepaintball posted Tue, 26 April 2011 at 7:33 AM
That solution is awesome, thanks for the help.
