kionde opened this issue on Apr 29, 2011 · 6 posts
kionde posted Fri, 29 April 2011 at 4:12 AM
what is the reason for complet different appearence of the rendering if i take a scene from 6 to 9 to render? in 6 it looks more or less natural, the same scene with same materials and same settings looks in 9 then like a preview mode.....
JCD posted Fri, 29 April 2011 at 6:56 AM
This is something I've noticed as someone who still uses Vue 6, but steps out into the new versions for their faster rendering capabilities. While it may not be all one thing, I've found it to be the lights and fringe atmosphere settings that cause the problem. My guess is that with each version of the app, Vue's light engine gets tweaked and therefore something that looks spectacular in an older version doesn't always look as good in later releases.
Just my .02, but what I've started doing is building my scenes and setting up .vob objects in Vue 6 and then lighting them in the latest release which seems to eliminate any surprises.
ShawnDriscoll posted Fri, 29 April 2011 at 8:07 AM
Version 6 and 9 use difference render engines among many other things. Treat them as different programs overall.
kionde posted Fri, 29 April 2011 at 3:02 PM
i will try like that, Jacob..
ChuckEvans posted Tue, 03 May 2011 at 8:48 AM
I guess a lot of people are still running XP--or does 6 Infinite run on Windows 7?
ShawnDriscoll posted Tue, 03 May 2011 at 5:57 PM
I'm using WinXP 32-bit 2GB RAM. Pretty old single core system.
