onefromb5 opened this issue on May 03, 2011 · 11 posts
onefromb5 posted Tue, 03 May 2011 at 4:43 PM
I am using photosho 5(Yes I know its outdated). I am making minis for a game I play online. I import the picture, remove the background with the magic wand, export as gif. I get white artifacts surrounding the mini after it is saved. I have tried matting/defringe and remove white matte. nothing has worked.
You can see them on the pic below.
can anyone help?
erosiaart posted Tue, 03 May 2011 at 8:36 PM
ah.you used the magic wand... did you smoothen out the edges after it was selected? click on refine edges to do that. also..you might want to try increasing the tolerance level.
work at 200-300% of the size to see exactly whta was selected and smooth the edges become.
for something like this.. i'd use the marquee tool and work my way around it.. or a mask..
cheers and hope that helps.
Lucie posted Tue, 03 May 2011 at 8:59 PM
The white pixels we see around your image are pixels that aren't either completely opaque or completely transparent, that's caused by the anti-aliasing when your remove the background. When saving as a gif, the pixels have to be either completely opaque or completely transparent, so those pixels that aren't 100% transparent are kind of merged with white when you export as a gif. I'm not sure if this is in photoshop 5, but see if there's an option with the magic wand to remove the Anti-Alias, in my version of photoshop, it's a little box that I check or uncheck, I guess if it's available in ps5 it's probably something similar. By using the wand with the anti-alias uncheck, the pixels of your image will be either completely transparent or completely opaque, no in between. I hope I'm explaining this well enough and it's not too confusing.
onefromb5 posted Wed, 04 May 2011 at 7:23 PM
I dont know what working with a mask is all about or how to do it.
I made some more today using the magic wand with anti alias off. Still geting the white edges around it.
Is there a way to save the image with a transparent background instead of EXPORTING it as a gif? A JPG is prefered as I have a ton of them to make.
Lucie posted Wed, 04 May 2011 at 8:08 PM
Here's your last one saved as a png just to show you how it would come out, I've removed quickly and roughly the white pixels around it and resaved is as a png.
onefromb5 posted Wed, 04 May 2011 at 8:26 PM
This looks awesome. Would like to know how you removed the artifacts?
Miss Nancy posted Wed, 04 May 2011 at 8:32 PM
see if APS5 has "matte colour" pref, tool, selector et al. then select matte colour to most closely match gif edge colour.
Lucie posted Wed, 04 May 2011 at 8:33 PM
I just answered your site mail.
Miss Nancy posted Wed, 04 May 2011 at 8:34 PM
if able to choose matte colour in APS5, edge will look smooth, at least in OS X. I dunno how it looks in win7, hence I used restrictive clours.
onefromb5 posted Thu, 05 May 2011 at 8:05 PM
erosiaart posted Thu, 05 May 2011 at 9:30 PM
great! well done! :-)
