Subject: concealed IDL emitters
seachnasaigh opened this issue on May 07, 2011 · 4 posts
seachnasaigh posted Sat, 07 May 2011 at 1:42 PM
I think I have a useful variation of BB's idea for night shots, at least for P8+, since it exploits IDL.  My Lothlorien-esque stairway models have a lot of lamps, and dealing with eighty point lights is a chore (and a render burden).  :(   I recalled the thread here regarding ambient-textured geometry used to light a scene, but the panels had to be searing blown-out white, even though the light they cast was modest.
     After several trial experiments, I finally managed to get an idea to work:  an intense IDL emitter hidden inside a gently-glowing lamp.  Using this method, you only dial the default scene lights down;  no other lights are needed - the emitter geometry does the work in IDL.  For day shots, you need only uncheck the visibility box for one item - the emitter array is a single prop. :)
     Here is a test render of the top flet on the gnarly mulberry;  default Poser scene lights are dialed down to 8%, rendered in P8 with 4 raytrace bounces at 90% irradiance cache:
audience flet
seachnasaigh posted Sat, 07 May 2011 at 1:54 PM
Attached Link: knothole nap
If you want to apply the "hidden emitter" method to other things, here is the secret:
     Link shows the knothole of the same huge mulberry tree, used as a napping cubbyhole, with a single nightlight.  ^^
     This is a raw Silo modeler screen capture of the mulberry tree with its stairway...
gnarly mulberry
seachnasaigh posted Sat, 07 May 2011 at 2:00 PM
Attached Link: elvish apartment flets in mallorn tree
     This is the "apartment flets" model, on a great mallorn tree.  Only the three default Poser lights are used, dialed down to 8%.  The lanterns use the hidden emitter technique.  Rendered with 4 raytrace bounces at 90% irradiance cache.
RobynsVeil posted Sat, 07 May 2011 at 5:59 PM
Wow! I love the feeling-tones in your images... what magic, Seachnasaigh! Very nicely done... and thanks for the tips!
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
