Subject: Dynamic Hair for distribution
vholf opened this issue on May 13, 2011 · 6 posts
vholf posted Fri, 13 May 2011 at 4:32 PM
From Poser Pro 2010's Manual:
"Saving a prop/body part with a hair object on it. In this case, simply add the prop with the hair to your scene. For example, you could use the Group Editor to select polygons on a character’s head and create a skullcap prop, grow hair on that prop, and save the hair and prop to the Library palette."
Is that an option when working with Victoria 4? Could I distribute the hair with the skull-cap created directly from Victoria 4 mesh?.
LaurieA posted Fri, 13 May 2011 at 4:48 PM
Quote - From Poser Pro 2010's Manual:
The short answer is no.
Daz doesn't allow any copying of the mesh for any reason. If there was a way to RTEncode it, then that would be your only option, but I can't help you with that ;).
patorak3d posted Fri, 13 May 2011 at 5:01 PM
That's stupid.
Cariad posted Fri, 13 May 2011 at 5:21 PM
Attached Link: Hair Modeling Tutorial by Valea
If you have access to a modeling app though a skull cap is quick to make and then you could.
Valea has a tutorial for her hair modeling method in Hexagon.  It starts with how to make a skull cap.  Also useful if you want to look into making conforming hair.
Any dynamic hair you created on your own skull cap wouldn't be an issue for distribution as far as I know.
Irish posted Fri, 13 May 2011 at 6:08 PM
Attached Link: Scull Caps
PhilC has some free ones.
vholf posted Fri, 13 May 2011 at 6:23 PM
Quote - The short answer is no. Daz doesn't allow any copying of the mesh for any reason. If there was a way to RTEncode it, then that would be your only option, but I can't help you with that ;).
That's what I thought, so that's why I asked. Thank you Laurie.
Rhionon and Irish, thank you for the links, those are very handy!
