santicor opened this issue on May 15, 2011 · 8 posts
santicor posted Sun, 15 May 2011 at 9:13 AM
I am not the most knowledgabele PC user here- so please have patience with this question - ( this is not as bad as my "how do i merge 2 light sets?" question, though)
I have some kind of library access http error every time I run PPRO2010 so i guess this uses the internet and I have some connectivity prob. can anyone help
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032" errorID=2032]. URL: http://www.contentparadise.com/api/search_params.aspx"] messageId="62FFB8C8-6709-0F38-F168-F3FA4072EF43" type="fault" bubbles=false cancelable=true eventPhase=2]
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
Victoria_Lee posted Sun, 15 May 2011 at 9:26 AM
If it's anything like the one I had, it's that a port is being blocked that the library needs.
I went into my firewall and opened all the ports for Poser and it worked.
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
bagginsbill posted Sun, 15 May 2011 at 9:28 AM
It's nothing. Your PC is configured to prevent the GUI from asking CP a question. The question it is asking is this: "What search parameters should I offer to help the user do a search on CP?" Then CP normally answers with things like "Search by Vendor" followed by a list of vendors, "Search by Category" followed by a list of categories.
I am sorry that I did not suppress the error message when I built it. I thought people would like to know that searching the store will not be possible. I did not anticipate the situation that is created when a user absolutely never allows their computer to talk to the Internet.
None of the beta testers reported this, which is when such scenarios are usually revealed. Otherwise if I had understood how a non-trivial number of people are affected by this, I would have added an option to disable CP search.
santicor posted Sun, 15 May 2011 at 10:07 AM
In windows firewall ( i do not have any other firewall) I just allowed full access to PPro2010 ....and I also understand the error that is happeneing b/c of BBs explanation.
at the risk of sounding thick ..... i continue to get the error accessing Content Paradise after setting rule in firewall - and then the second error after the CP error is this:
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032" errorID=2032]. URL: http://127.0.0.1:11530/apps/lms/api.py"] messageId="0F6E1FBD-9649-F5C9-0892-F42E566F0AA3" type="fault" bubbles=false cancelable=true eventPhase=2] --- Fault Request Info:
op=appConfig
but the main problem is, after dismissing these 2 error notifcations I have blank screen for library.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
bagginsbill posted Sun, 15 May 2011 at 10:22 AM
The second one is much more serious - failure of the "appConfig" request. It is unable to talk to Poser itself. This is the very first internal communication and it is the configuration of the GUI itself - what are the 9 categories of content, what are the library paths, what are the options allowed on them, what are the words and pictures on every part of the interface, etc. Without a response to this, the GUI is like a blank sheet of paper - it knows nothing at all.
The firewall is not allowing any communication, even internal to the machine. You must fix that.
santicor posted Sun, 15 May 2011 at 6:41 PM
Fixed the isue by yanking the factory Mcafee (relatively new Dell desktop) and buying Kaspersky - that mCafee is a curse I should have done this long time ago
I simply could not manage that horrible mcafee and it did not even want to uninstall for me - fought me for an hour
Library access is fine now - both the windows and kaspersky firewalls are up with no special rules needed for Poser and it works fine.
Thank you
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
bagginsbill posted Sun, 15 May 2011 at 7:18 PM
Awesome. Earlier mentioned you thought you only had Windows firewall - if I had even a hint of McAfee I would have told you to dump that junk. That is the worst security software in the world. I was forced to use it for a while while I was consulting for a very large corporation because of their stupid rules. It slowed my work down so bad I was losing money! So I secretly removed it from their computer.
They insisted that it was not possible to remove their corporate security policy as it was enforced. I actually did it (bypassed and completely erased) in less than half an hour. McAfee is total junk. It interferes with the user, and does not prevent hackers like me for more than a couple minutes.
ShaaraMuse3D posted Mon, 16 May 2011 at 2:04 AM
That error message has appeared for me too. Usually appears when I have wireless switched off (using laptop). I just click it away and continue. :)
