dante opened this issue on May 15, 2011 · 7 posts
dante posted Sun, 15 May 2011 at 4:28 PM
Upon importing an OBJ file with textures after it had been exported from 3dMax the mesh came fine showing all textures as they should be (1st Pict). But after rendering the textures showed like what you see in the 2nd pict.
How can I correct this?
Thanks in advance
dante posted Sun, 15 May 2011 at 4:29 PM
millighost posted Sun, 15 May 2011 at 5:09 PM
Quote - here's the second pict
Looks like two overlapping cars. You probably either accidently loaded your car twice into poser, or you might have duplicated every face in 3dsmax.
dante posted Sun, 15 May 2011 at 5:16 PM
Thanks...I think you are right...let me check.
jonnybode posted Sun, 15 May 2011 at 11:44 PM
Or you could check out "normals forward" in the material room, or "smoth polygon" under properties.
nruddock posted Mon, 16 May 2011 at 3:24 AM
Quote - check out "normals forward" in the material room
This will likely be the quickest solution. A better fix would be to export with whatever option will produce single sided polygons (this may require some fixup depending on exactly what comes out).
232bird posted Mon, 16 May 2011 at 8:31 AM
What version of Max? I have 2010, and I know it has a Poser preset for the GW obj exporter. Or maybe the preset is in the exporter. I don't know, come to think of it. The exporter is a free download if you search for it. Anyway, it automatically corrects alignment, grouping, (mostly) sizing, and has options to bake textures as well as export the textures as well. It isn't perfect, but may fix your problem.
