Subject: how to increase the size of the icons in the poser 8 library
rowlando opened this issue on May 26, 2011 · 8 posts
rowlando posted Thu, 26 May 2011 at 6:33 PM
thats it thanks Rowlando
Seek what you can never loose
Afrodite-Ohki posted Thu, 26 May 2011 at 7:18 PM
Way down your library, there is a small bar that's clickable and should open a set of options. One of those options allows you to increase thumbnail size (and there are options to customize pretty much everything in your library there).
Feel free to call me Ohki!
bagginsbill posted Thu, 26 May 2011 at 10:54 PM
Make sure you have Poser 8 SR3.1. There are more options in the update than the original program.
And there is considerable explanation of the library in the Poser Reference Manual that comes with the program. You'll reach it in the help menu.
rowlando posted Fri, 27 May 2011 at 1:57 AM
hi Thanks for the advice and yes found what I wanted for the size of icons all good.
Just one other thing I cannot find how to do if it can be done, I looked in manual.
So re library it displays one icon per line so on my 2nd screen I have multiple rows with just one icon on each row.
unlike the poser 7 library that showed many icons beside eachother so I am hoping this same layout can be achieved with the new library?
I use a second monitor to view my library contents so I am not having to click click so much in order to see what I wanting.
I don't go by name but by memory of sight concerning the icons hope you can still help.
O got the SR3 update installed
bagginsbill posted Fri, 27 May 2011 at 8:03 AM
Prior to SR3, the tree view was the only option and that is one item per row.
In SR3, you have also a tiled-list view, which can show many items per row. There is also a breadcrumb bar showing the path of the folder you're looking at. You also have a detail panel to show all the metadata associated with an item. You have the option to show just the tree, just the tiled-list, or both, and your choice also as to whether or not to show the breadcrumbs and the details.
The icons sizes are adjustable for the tree, the list, and the details. As well, the sizes of the panels themselves are under your control.
vilters posted Fri, 27 May 2011 at 9:06 AM
@BB :-)
Next release SM should put a big red flashy arrow pointing to that toothpick.
You answering those Q's every 2 days........ :-)
PS, tonight, i'm gonna make my floor...
Correction, try to....... reproduce it.
rowlando posted Sat, 28 May 2011 at 2:17 AM
thanks bagginsbill
I need to find these adjustments and will, need to check my SR3 update is done.
The library will do everything I want since SR3 so thanks again
Rowlando
