Subject: V4 thunder thighs
Klebnor opened this issue on May 27, 2011 · 6 posts
Klebnor posted Fri, 27 May 2011 at 8:09 AM
Is there any way to eliminate the grotesque bulging of the front of V4's thighs when her legs bend?  I mean really, outside of a russian female weight lifting event, whose legs do that?
Is there a way to eliminate the magnet(s) respondible for this ridiculous bulge without removing all the ++ leg morphs?
Thanks.
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device.  Beige horizontal case.  I don't display my unit.
Cariad posted Fri, 27 May 2011 at 8:25 AM
If you are planning to cover her legs in clothing there is a set of thigh fix inj on sharecg that can be helpful.  Otherwise, I have never found a way to fix them really save for some judicious dial tweaking to try to compensate for some of it, and that is still not perfect by a long shot.
vilters posted Fri, 27 May 2011 at 9:01 AM
You could walk the thights over with the Morph brush?
Or us a magnet for each thight? This seems the best option to maintain the left-right.
TheOwl posted Fri, 27 May 2011 at 10:08 AM
Attached Link: http://www.renderosity.com/mod/freestuff/details.php?item_id=55553
maybe this?
Passion is anger and love combined. So if it looks angry, give it some love!
Klebnor posted Fri, 27 May 2011 at 10:22 AM
Thanks to all.  I like pgmeri's work very much, will try his solution.
Cariad posted Fri, 27 May 2011 at 3:01 PM
Quote - Thanks to all.  I like pgmeri's work very much, will try his solution.
Those would be the ones I was talking about.  I grabbed them from sharecg though, didn't know they were here too.
