Subject: Origin
eltoro3D opened this issue on May 27, 2011 · 8 posts
eltoro3D posted Fri, 27 May 2011 at 9:20 AM
After I know how to display the origin of a figure or a prop .. I want to know how can I move the origin so i can scale something in the right way ..?!
Thanks a lot
geep posted Fri, 27 May 2011 at 9:47 AM
Attached Link: "Origin" Tutorial - compliments of Dr Geep Studios
*(click the image to view full size)* *(click the link above the image to view the tutorial ...)** (... then scroll down to view all the pages in the tutorial)*
Done for Poser 4 but should still work. :biggrin:
See Page 5 ! 👍
Enjoy. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Fri, 27 May 2011 at 9:57 AM
If you are using Poser 8 ...
... then check this one ... (see image above)
... and ...
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Fri, 27 May 2011 at 9:58 AM
... then adjust the parameters here.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
eltoro3D posted Fri, 27 May 2011 at 10:00 AM
Thanks alot :)
geep posted Fri, 27 May 2011 at 10:13 AM
cheers,
dr geep ... :o]
edited 10/5/2019
RLSprouse posted Tue, 14 May 2013 at 12:34 PM
I am using PP2012 on an iMac 27" system with OS X 10.4
When I select a prop I made, and then check the "Display origin" checkbox, I do get the green crosshairs, but the three Origin parameter dials do NOT appear.
How do I access those dials?
  ~ Russ  (a.k.a. Ansel)
Allstereo posted Tue, 14 May 2013 at 10:19 PM
Hello,
Move the current camera a little bit to force an update of Poser.
Allstereo
