3dBim opened this issue on May 28, 2011 · 3 posts
3dBim posted Sat, 28 May 2011 at 2:28 PM
I have asked for help in the animation upload department and I would like to mention a couple of things that might help out others.
(although I have still not been sucessful :o) )
To access it, click on features/animation. Click on the upload tab and scroll down past the search freebees to find an up-load section much like galleries.
Unlike the regular gallery upload; if you have made a mistake, ( like uploading the wrong resolution for your thunbnail), you will not be informed, there is no incorrect format messages :o(
Your file is limited to 50Megs, so longer animations need to be rendered in lower resolutions :o) and must be placed in a zipped folder.
Thumbnails resolution is 200x200. (That looks like a requirement).
I uploaded my animation yesterday, (for the third time this month), and if this turns out sucessful, I will be back to confirm and clarify as best as I can.
Rick
3dbim
PoserPro 2012
3dBim posted Wed, 08 June 2011 at 6:14 PM
I can confirm that the aforementioned is the correct procedure for uploading animations here at renderosity :o)
3dbim
PoserPro 2012
3dBim posted Thu, 09 June 2011 at 10:37 PM
Hmmmm... Animations should be released by 24 hours of posting at renderosity.
If anyone has questions about animation uploads please ask and I will find out and post it here if it is something that I do not know.
One correction. If there is a problem with format or info, I have been informed that there will be an error message at upload.
So, If you do not see one and your animation is not up please inquire or post here :o)
3dbim
PoserPro 2012
