Nyghtfall opened this issue on May 29, 2011 · 5 posts
Nyghtfall posted Sun, 29 May 2011 at 6:21 PM
Is there a way to have Poser identify the name of an object when I mouse over it in the Preview window?
hborre posted Sun, 29 May 2011 at 6:45 PM Online Now!
Nope. You must select by clicking.
PhilC posted Sun, 29 May 2011 at 6:46 PM
Yes, depending on your version, right click and it will pop up a select menu.
hborre posted Sun, 29 May 2011 at 7:05 PM Online Now!
Phil, I think the OP means actually seeing an object name while mousing over. Mousing over will definitely select the object or actor part by highlighting that area in white, however actually seeing an identification label popup will not happen unless you left- or right- click.
Nyghtfall posted Sun, 29 May 2011 at 8:00 PM
Quote - Phil, I think the OP means actually seeing an object name while mousing over.
Correct.
Quote - ... actually seeing an identification label popup will not happen unless you left- or right- click.
Thank you for clarifying.
