Forum: Vue
Subject: Grunge or multiple layers
GeneralNutt opened this issue on May 31, 2011 · 5 posts
GeneralNutt posted Tue, 31 May 2011 at 10:19 PM
I know this is probably simple, but for days if not weeks, I've been trying to make a grunge or dirty layer for a material in vue. I have a layer with texture maps, but wanted to add a dirty layer to add to it procedurally. Either it shows up semitransparent, not at all, or completely takes over. Am I misunderstanding how layers work in VUE?
ShawnDriscoll posted Wed, 01 June 2011 at 12:12 AM
Mixed Material used?  Mixing Proportions set at 50%?  Value and contrast the same for both materials?  Distribution of Materials is using a Grainy Fractal (not the default Simple Fractal)?  Clicked the Swap icon to reverse the mix order of Material 1 and 2?
GeneralNutt posted Wed, 01 June 2011 at 12:39 AM
I tried mixed material, and just adding a material. I played with mixing proportions at many settings. Value and contrast, I never thought of, thanks. I don't think I tried the grainy fractal, but I did try others. And yes I tried flipping the mix order, it switched things up, but didn't get where I wanted. Thanks for your help, I'll look into those things.
GeneralNutt posted Wed, 01 June 2011 at 1:18 AM
Thank you so much. It works, I don't know, I guess I was over complicating things before.
silverblade33 posted Wed, 01 June 2011 at 6:53 AM
Well for demonstration of this point, here's my freebie "dirt/grunge" material layer for Vue8 and above :)
http://www.silverblades-suitcase.com/vue_mats/Steves_Layered_Dirt_V8.zip
it works both procedurally AND with a texture, I put input nodes in for such (you nna blend them), so you can for example, use a UV map to drive specific placement of grunge/dirt, which is how I make ship decks/hulls have staining drippign down them, or in certian areas etc.
