Steeleyes101 opened this issue on Jun 12, 2011 · 7 posts
Steeleyes101 posted Sun, 12 June 2011 at 4:19 PM
Hello all and once again hope you are all having a wonderful weekend
Listen I thogut I had ask this once but cant find the thread if I did, so asking again.
Please can someone tell me if it is possible to resize a layer once I have placed it on my orig picture in Photoshop.
I want to make borders useing multiple layes but cant figure out how to do the following.
1, make my outter layre larger then the orig picture.
2, Crop the inner part of the layre that will be placed over the orig picture or second layer.
Any info will be much appreciated
Steel
Attached you will see what I already have
dreamer101 posted Sun, 12 June 2011 at 5:33 PM
If you are going to make a layer larger than the original image you would first increase canvas size:
Image > Canvas Size
To increase size of a layer you would first select the layer then:
Edit > Transform > Scale
Steeleyes101 posted Sun, 12 June 2011 at 5:36 PM
Thanks Dreamer very much appreciated
Steeleyes101 posted Sun, 12 June 2011 at 8:35 PM
If you look at the screen print attached you will see a little lock next to the blank layer which will later be black in the Layes menue.
Can someone tell me please how do I unlock so I can move it behind my main picture?
Thanks again
Steel
erosiaart posted Mon, 13 June 2011 at 4:28 AM
i don´t have photoshop on the computer me using..but if you click on the lock.you should be able to unlock it. or else.. right click..and you´ll see a couple of options..one being make layer or something to that effect.. think you ought to see unlcok too.
Lucie posted Mon, 13 June 2011 at 6:33 AM
You're talking about the background layer, right? If so, try double clicking on that layer, it should do the trick.
mairaj posted Wed, 13 July 2011 at 2:39 AM
Attached Link: free tutorials
Resize a layer in Photoshop1. Select the layer
2.Type Ctrl-T to transform
3. Drag on corner handles (hold Shift button to constrain proportions)
4. Double-click inside to commit
