bjbrown opened this issue on Apr 28, 2001 ยท 8 posts
bjbrown posted Sat, 28 April 2001 at 5:43 PM
In the attempt to create what I would consider to be the perfect Vicki shorts, I tried to create a new shorts object from the Vicki pants (which comes in the DAZ CD).
There are holes in my new shorts, apparently in the seams where the objects connect. I would like help to determine how they got there and how to close them up.
To the extent that it helps, I did the following to create the shorts:
AlleyKatArt posted Sat, 28 April 2001 at 7:53 PM
You didn't move them all at once. So there are seams. I think it can be fixed in scaling, but I won't swear to it.
Kreations By Khrys
ScottA posted Sat, 28 April 2001 at 9:20 PM
I think what will happen is if you convert the shorts into a figure. And make sure that there are weld statements for each part like there normally is. Those holes will go away. Poser has the ability to pull seams together if the .cr2 file contains the proper weld statements. ScottA
bjbrown posted Sun, 29 April 2001 at 9:43 AM
Is pulling the seams together something I cannot do within Poser itself? I notice that the grouping tool has a Weld Group option, but that doesn't seem to let me weld different props.
BillyGoat posted Sun, 29 April 2001 at 9:59 AM
Those shorts are gonna be great! You wanted a more sexy short, and this looks like it's going to be prefect. Please post them when you're finished. How hard was it to do?
Mason posted Sun, 29 April 2001 at 7:40 PM
For weld to work, all the vertices must be exact (or within extemely low tolerances). Also make sure the bend check box is turned on for each part.
bjbrown posted Mon, 30 April 2001 at 7:05 PM
How do I weld the pieces together? I found an option for welding groups, but not props. I'd appreciate a step by step, down to with what menu I use to start.
ScottA posted Mon, 30 April 2001 at 7:18 PM
The weld thing only works if you convert the shorts into a figure. Poser looks at the weld lines of the .cr2 file to pull the seams together. This can't be done with a prop. As far as I know. ScottA
