Helgard opened this issue on Jun 14, 2011 · 10 posts
Helgard posted Tue, 14 June 2011 at 11:05 AM
Attached Link: Buildings 4
Ultra low polygon models with an "old Europe" flavour, some war damaged by fire and bullet holes. Includes a basic terrain with roads and a park area.
Your specialist military, sci-fi, historical and real world site.
The entire scene in the PZ3 uses less than 200 polygons. The PZ3 of this scene is included in the product.
Meant to be used as distant background elements or to fill up the scene behind other higher polygon models.
Please note: In DAZ/Studio this model loads without the textures applied. It is a simple cube. Just apply the diffuse, bump and trans maps and the model will work.
bobbystahr posted Tue, 14 June 2011 at 11:13 AM
JeBus...thanks again. Soon I'll have a small city. Guess I better start creating a terrain for it.. ...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Helgard posted Tue, 14 June 2011 at 6:20 PM
Terrain is included, but it is low poly. You will have to add your own trees, trash cans, street lights, road signs, etc.
Nance posted Wed, 15 June 2011 at 1:06 AM
Thanks again Helgard. These has been a well done & really handy series.
...but, was there a "Buildings 1" set that I missed? Didn't spot one at OnTarget3D with your other works.
Helgard posted Wed, 15 June 2011 at 4:53 AM
Buildings 1 was just called "Buildings". Here is the link:
http://www.ontarget3d.com/site/Products/1085-buildings-for-poser.aspx
bobbystahr posted Wed, 15 June 2011 at 7:40 AM
Got that Helgard, I was referring to the environment I drop the streets into...I use mainly Terragen2 and everything is a terrain there, heh heh heh
Once
I see
a sound
and
Sometimes
Nance posted Wed, 15 June 2011 at 11:44 PM
Sure enough! Right there all along. Thank-you for reposting the link Helgard.
Helgard posted Thu, 16 June 2011 at 7:01 PM
Bobby,
Ranman38 is working on a set of low poly streets and pathways and walls for adding to terrains. It will be quite innovative, as it is textured with procedurals, so that you can stretch it on the x and z axis without texture distortion. Obviously that only works in Poser though, not terragen.
Helgard
bobbystahr posted Sat, 18 June 2011 at 2:25 PM
I look forward to seeing it. I have an offline Poser friend I'll show it to as well...I personally should be able to remap it from my huge ImageMap dir for terragen2 use.. ...
Once
I see
a sound
and
Sometimes
