dyo opened this issue on Jun 20, 2011 · 12 posts
dyo posted Mon, 20 June 2011 at 9:06 PM
Hi people
when I import an image as a back ground at say 1600 by 1200, i set the render size to 1600 by 1200 but the render gives me white on each side of the image.
Why is the background not filling the render window ?
thanks in advance
DYO
Dyo Sloneclaw
Struggling unemployed Artist
Poser 6 on VMware Fusion windowsXp immulator on mac osx 10.6.7
bagginsbill posted Mon, 20 June 2011 at 10:42 PM
In the Background material in the node where the background image is (usually called BG Picture) there is a check box called Auto_Fit. Turn it on.
dyo posted Thu, 23 June 2011 at 9:35 PM
Thanks bagginsbill
The full render is fine, but its when i render a quick version in firefly , that the back ground pic is squashed ?
So I cant see if the image is in the right location .
regards
DYO
Dyo Sloneclaw
bagginsbill posted Thu, 23 June 2011 at 9:54 PM
I'm afraid I don't understand you. I don't know what it means to render a "quick version in firefly".
Do you mean something else than rendering in firefly? There is no "quick version" of firefly.
dyo posted Thu, 23 June 2011 at 10:01 PM
Hi bagginsbill
I mean the render settings are on "Draft" not final
the back ground photo is squashed side ways with white on both sides , in a final render this does not happen .
just a bugg i guess
thanks
DYO
Dyo Sloneclaw
bagginsbill posted Thu, 23 June 2011 at 10:08 PM
What OS? What version of Poser? What SR? (Put this info in your signature - and please ask everyone else to do so. It seems like I ask these questions preparing to help somebody about 20 times a week.)
I cannot reproduce what you describe.
dyo posted Thu, 23 June 2011 at 10:35 PM
Hi Bagginsbill
I have added the OS and poser version but what is SR ?
im not good with the operating systems stuff or typing for that matter :( sorry
each time I get a good image in poser i think its a small miracle :)
DYO
Dyo Sloneclaw
bagginsbill posted Thu, 23 June 2011 at 10:39 PM
SR stands for Service Release - when Smith Micro puts out an update to a previously released version of Poser to fix bugs.
I no longer have Poser 6 to compare behaviors with you. Perhaps somebody else can help.
dyo posted Thu, 23 June 2011 at 10:46 PM
Ok thanks for trying
I hope to update soon to poser 8 when I get some spare cash !!!!!!
BTW nice tatts on Ladywolf
DYO
Dyo Sloneclaw
nruddock posted Fri, 24 June 2011 at 2:12 PM
For P6, you also have to change to "Maximum Texture size" to be equal to or larger than the biggest dimension of the background image.
Rainfeather posted Fri, 24 June 2011 at 2:43 PM
Try this under Settings > Render Setting then move the slider up as shown below:
Make sure the max texture size is equal or bigger than the background size (as nruddock) mentioned.
dyo posted Sun, 26 June 2011 at 11:27 PM
Thanks rainfeather and nruddock
I will keep an eye on the max texture size when rendering from now on
Dyo Sloneclaw
