Arah opened this issue on Jun 28, 2011 · 15 posts
Arah posted Tue, 28 June 2011 at 2:54 PM
LaurieA posted Tue, 28 June 2011 at 3:03 PM
looks like a concave face or non-planar facet. Can you still see it when rendered?
Arah posted Tue, 28 June 2011 at 3:08 PM
Yes unfortunetly it's still there when i render it in poser.
markschum posted Tue, 28 June 2011 at 10:32 PM
try 'normals forward' and then try turning shadows off for the dress. See what happens.
Winterclaw posted Tue, 28 June 2011 at 11:12 PM
You also have white spots.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Arah posted Wed, 29 June 2011 at 5:45 PM
Yes i have spots of both colors, how to i turn normals forward?
I made a new skirt, and that seemed to fix the problem, but it doesn't have such a nice UV map as the other. so i'd like to see if i can fix the problem, if not, oh well.
LaurieA posted Wed, 29 June 2011 at 5:55 PM
You do normals forward in the materials.
Arah posted Thu, 30 June 2011 at 4:08 PM
Thank you!
Arah posted Thu, 30 June 2011 at 4:34 PM
Hm tried it, but no luck. oh well, i'll just work with the other for now, thanks anyway!
nerd posted Fri, 01 July 2011 at 6:09 AM Forum Moderator
Try turning the crease angle for that object waaaaay up, like 180. It looks like what's happening is some of the polys are getting creased while others are not.
Arah posted Fri, 01 July 2011 at 9:07 AM
How do i do that? sorry i'm not that firmilier with all the points of poser.
nerd posted Fri, 01 July 2011 at 10:38 AM Forum Moderator
On the Object's Properties Tab there is an Crease Angle setting. The default value is 80. You can change the default value in prefrences. That would effect every thing new from that point forward.
Arah posted Fri, 01 July 2011 at 1:09 PM
Hm. No luck, thanks though.
vilters posted Fri, 01 July 2011 at 1:17 PM
Did you render?
Crease angle is only calculated at render time.
I would start by normals forward and crease angle at 180 and render.
You can set crease angle for every part in the parameters palette, or for the whole scene.
Goto General preferences, and set the crease angle there. 'default is always 80 but you can go to 180.
But from here, it looks more like a problem in the mesh.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Arah posted Fri, 01 July 2011 at 1:50 PM
Yeah i think it was the mesh, i made a new one, and it seemed to be ok, so i think it was just something in the old skirt. Thanks for all the help!
