Subject: Poser Preview Window Question - I feel stupid asking this but I need to know
PXP opened this issue on Jun 29, 2011 · 12 posts
PXP posted Wed, 29 June 2011 at 9:09 AM
Basically some hair will not display colour in the Poser preview window before a render whereas other hair products do.
I really feel silly asking this question But why is this happening? Is it controllable and if so how? or is it down to the artist/creator who made it?
Really could do with an answer to this.....
ElZagna posted Wed, 29 June 2011 at 9:15 AM
Actually, this is a question I've had also. It happens with certain outfits also.
OS: Windows 10 64-bit, Poser: 10
bagginsbill posted Wed, 29 June 2011 at 9:18 AM
Display/Figure Style or Display/Element Style
Either could be doing it. Use the menus or ...
Select it and press ctrl-alt-9 and ctrl-shift-9
hornet3d posted Wed, 29 June 2011 at 9:23 AM
I have seen this and sometimes ticking 'enable hardware shading' under the preview tab of render settings has corrected this.  However it does not always solve the probelm and can create more problems in the preview.
wimvdb posted Wed, 29 June 2011 at 9:49 AM
Another possibility is that there is no texture attached to the diffuse channel. If you have a node setup which uses the Alt-Diffuse and has the diffuse channel at 0, you can still attach the texture to it and it will show in preview
PXP posted Wed, 29 June 2011 at 10:11 AM
bagginsbill
Thank you so much I know it was a dumb question but you answered it for me.
It was the Display/Element Style that needed to be set to texture shaded.
Thanks a lot.
hornet3d posted Wed, 29 June 2011 at 10:58 AM
As an ex-trainer my definition of a dumb question was  - one that was thought of but never asked.  On a forum like this I accept it can be annoying if the question has been asked a number of times before no-one bothered to do search before hand.
Point is I had noticed the same thing and did not know the answer so I did not regard it as a dumb question and now, like you, I have an answer to it.  So thank you PXP for asking and also BB for providing the answer to yet another of my 'I wonder why' questions.
bagginsbill posted Wed, 29 June 2011 at 11:36 AM
Hey I remember it stumping me in the beginning as well. Even if this was answered before, I would not know how to find the answer via searching with any efficiency. It was easy to ask and easy to answer. No biggy.
lkendall posted Wed, 29 June 2011 at 11:52 AM
Thanks for the question and answer, it stumped me also. But, it never occured to me to ask.
lmk
SamTherapy posted Wed, 29 June 2011 at 11:53 AM
Some hair makers have the display setting hard coded in, I believe.  So, checking "Texture shaded" makes no difference.  IIRC, some of Koz's hair is like this.
RobynsVeil posted Wed, 29 June 2011 at 5:13 PM
Quote - Some hair makers have the display setting hard coded in, I believe.  So, checking "Texture shaded" makes no difference.  IIRC, some of Koz's hair is like this.
For that sort of problem, you can just go into your hr2 file or cr2 file with like Notepad++ or some pure text editor for the hair or whatever and do a search for "displayMode". Replace "WIREFRAME" with "USEPARENT". I'd save the fixed versions as:
"MyHair Textured.hr2"
or something like that.
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
lesbentley posted Wed, 29 June 2011 at 9:38 PM
 Certainly the element display style is normally coded into every actor in a cr2, and the overall figure display style is also specified in the cr2. However it's not "hard coded", you can always change the Display Style via the Display Style palette.
You should remember that there is a 'Figure  Display Style', and an 'Element Display Style', and you may need to set either, or both, to get the desired style. I'm not knocking RobynsVeil's advice. Of course if you want to fix it permanently at the source, edit the cr2. But for those who may not feel comfortable editing Poser files, just use the Display palette.
