Forum: Vue
Subject: RAM not getting used more than 3 gb
valmik opened this issue on Jul 07, 2011 · 6 posts
valmik posted Thu, 07 July 2011 at 1:16 PM
hey guys need help , i am using I7-950, 8gb RAM, win 7 64 bit.
while i render scenes, the maximum RAM used to render a scene is 3 gb. y doesnt Vue use more than that, so tht it speeds up my work.
pls help!!!
bruno021 posted Thu, 07 July 2011 at 1:26 PM
Maybe because it doesn't need more than that on this particular scene?
aRtBee posted Thu, 14 July 2011 at 7:35 AM
depends on your Vue. If it's 32-bit itself, 3Gb is the absolute upper limit. For more you need a 64-bit version.
I just shifted fom VueComplete 32 to VueComplete 64 when my 64-bit machine arrived. Just download your Vue again, install and reregister using the same serial as for the 32bit.
Hope this helps.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
bruno021 posted Fri, 15 July 2011 at 8:49 AM
Well, he did mention Win7 64bit...
aRtBee posted Fri, 15 July 2011 at 9:41 AM
yeah, I know, otherwise he had get another answer.
But no-one (but himself) stops him to install his good old 32-bit Vue on a 64bit OS.
The logic is:
if you run a 64-bit OS
   then if you run a 64-bit program: all is fine
   else if you run a 32-bit program which is LargeAdressAware (LAA): 3gb is the limit
       else 2gb is the limit (non LAA software)
else (you run a 32 bit OS)
   then 2gb is the limit
   unless your software AND your OS are LargeAddressAware, or made so
see my tutorial: http://www.main.artbeeweb.nl/?p=2429
(which currently resides in the Renderosity Poser section. I will update it a bit, and republish in the Vue section).
The 32-bit Vue versions are all LAA from Vue 8 up. That's why he gets 3gb user memory from his 64-bit OS.
All the best
bruno021 posted Fri, 15 July 2011 at 10:58 AM
Oops, sorry, hadn't understood your initial post!
