byheart opened this issue on Jul 16, 2011 · 3 posts
byheart posted Sat, 16 July 2011 at 3:26 PM
Fairy for Mavka is makeup on transparent background which I apply to skin texture or makeup on skin textures without the body? I have messaged both artists with this question and neither has responded . . . could you open it up and look for me?
IF it's the first, I want it; if it's the later, I don't . . .
rebelmommy posted Sun, 17 July 2011 at 3:30 PM
I don't have the product so I can't open it and check but since it says it is consisted of make up on psd layers and also states that it is a merchant resource, I would assume that you are correct that it would be transparent background make up that you could apply over any texture you want :D
As I said I don't have the files so this is probably the best answer I can give you :(
Sorry that you haven't gotten an answer from the product creators, perhaps they have not been online.
Renderosity's "problem Child"
Support Hydrocephalus research.. because a Shunt is NOT a cure!
Lucie posted Mon, 18 July 2011 at 7:32 AM
If you look at the file list in the readme it says:
Documentation
License0409.txt
Fairy for Mavka ReadMe.txt
Eyshadows.psd
Eyes.psd
Lips.psd
Makeup.psd
Backgrounds
The 10 eye shadows are probably all on separate layers in one psd file, same with lips etc, most likely all on a transparent background.
