willdial opened this issue on Jul 23, 2011 ยท 15 posts
willdial posted Sat, 23 July 2011 at 1:53 PM
Since I started to use Indirect Lighting in my renders, Poser Pro 2010 is constantly creating holes im my image. I found the holes are filled with background color. See the example above.
I get them on Poser Pro 2010 and Poser Pro 2010 SR1. I rendered on different systems and still get them. I rendered with both 64 bit and 32 bit Poser Pro 2010 and still get them.
Observations:
I found the using the Normals Forward in materals does not affect them.
I found a lower the Shading Rate procuces more holes. However, in a high shading rate the textures and shadows look bad.
If I rotate the Camera, I noticed the locations of the holes change. They can appear anywhere.
If I render to a smaller image size, the image contained fewer holes.
Technical Specs:
Poser: Poser Pro 2010
OS: Win7
CPU: Intel i7-950
RAM: 16GB
HD: 2TB
Render Settings:
I will post my render settings next.
Any thoughts or insights would be appreaciated.
Thank you.
