BJWxMan opened this issue on Jul 30, 2011 · 5 posts
BJWxMan posted Sat, 30 July 2011 at 4:54 PM
On occasion the looping function just won't quit. I have installed the SRP hoping it would resolve the issue but it doesn't. I tried sifting through the forum and Smith-Micro for anwsers/resolutions to no avail. Any ideas?
Thanks
markschum posted Sun, 31 July 2011 at 10:04 AM
Are you refering to the animation loop interpolation thing ?
an easy way to loop an animation is to copy the first frame to the end frame , keyframe the one before that and then delete the end frame
e.g copy frame 1 to frame 30 , keyframe frame 29 , delete 30 , perfect looping anim
BJWxMan posted Mon, 01 August 2011 at 2:05 AM
Thank you for responding.
The problem I run into is that after setting up an animation, I test it out by running the loop. Usually after a couple of loops ( and figuring out heads don't turn that way ;) I toggle the 'stop' button on the animation palette. Only in Poser 8, the loop continues to run. I tried pressing ESC, multi-tapping the stop button, cursing myself for not having saved the hour's work, etc. Eventually I have to go to the Control Panel to 'End Task' the program. I looked over the enclosed command card and could find no keystroke combination to stop the loop. Again, I've only encountered this problem with Poser 8 and its only happened a few times so I'm not sure if there's some new feature in Poser 8 that I'm overlooking or inadvertantly activating.
Again, thanks for your response and any help/advice you can provide.
3Dave posted Mon, 01 August 2011 at 3:53 AM
Try hitting the "Enter" key on your keyboard, it works to stop/start animation playback
ratscloset posted Mon, 01 August 2011 at 2:19 PM
I do something accidentally and get that... and I do something else to end it, but I can not recall what I do that causes it, and I can not recall what I do to stop it. I want to say I click on the figure in the Work Space, but I think that is when I notice the animation looping.
It should not happen when clicking on the Play button. If you get this everytime, contact Support. (Put Attn: John in the subject) Site mail me the incident and I will take a look at the issue and help figure out the cause and solution hopefully.
ratscloset
aka John
