Subject: I can't resize my library window.
Prometheus273 opened this issue on Jul 31, 2011 · 6 posts
Prometheus273 posted Sun, 31 July 2011 at 2:26 PM
Help.  Somehow my library window expanded so that I can't access the bottom corner to resize it.  How can I make it smaller?  If I drag it upwards it touches the top of the screen and expands.  I tried changing the preferences so that it launches to the factory state but the library window still goes past the bottom of the screen.  Any suggestions?
Paloth posted Sun, 31 July 2011 at 2:41 PM
Undock the Library window if it isn't already. Size the window down from the top, then drag it up. There are other ways as well.
Prometheus273 posted Sun, 31 July 2011 at 3:11 PM
Thank you.  I knew there was an easy way to do it.
Now I'm trying to set my  preferences again, but I can't get rid of Andy.  Every time I try to delete him, Poser crashes.
Acadia posted Sun, 31 July 2011 at 3:11 PM
If that doesn't work.
1.  Try going to the windows section and changing the size of the document window there.
Or
2.  In Preferences, make sure you not only change to "Factory State", but also that you look under the other tabs as well. There is one other section you need to change before everything reverts back to default upon reloading Poser.
Prometheus273 posted Sun, 31 July 2011 at 3:32 PM
Thanks Acadia.
I did do both before I got Paloth's response but they didn't work.  But thanks for the response anyway.
Now I have new problems.  I started another thread.
vilters posted Sun, 31 July 2011 at 4:30 PM
close poser
Delete all Poser preference files.
Poser will build a new set on its first startup again
