Subject: Need Poser Pro 2010 Tutorial On Basics
zonkerman opened this issue on Aug 07, 2011 · 3 posts
zonkerman posted Sun, 07 August 2011 at 7:56 AM
Hello All.
I recently upgraded to Poser Pro 2010. Last time I used Poser was back in version 7. The interface in Poser 2010 has changed so much that I realize I don't know how to do some of the basic things I used to do in version 7. I can't find any clothing options to load onto charactes like Ryan (maybe there is no free extra clothing out of the box?).
I'm not sure why the software loads up with a blue maniquin instead of a person like all the prior version.  If anyone knows of any good beginner tutorials that explains how to use Poser 2010 to work with the built in humans and cloth them as well as cover the interface please provide web links.  Thank you in advance.
hborre posted Sun, 07 August 2011 at 8:25 AM
Clothing content for Ryan and Alyson are now found under props as it should have been defined from the very beginning.  See illustration.
The blue android, Andy, is now the default mannequin for both Poser 8 and PP2010.  You can always change it out for Andrea or any other figure you desire.
I recommend that you take a look at the manual, it does contain basic operations.  The layout has changed and new features have been added, otherwise most tasks remain the same as other versions.
BTW, do install the latest service release, it corrects some problems discovered in the original release.
zonkerman posted Sun, 07 August 2011 at 8:51 AM
Hello hborre. Thanks for the info. When I saw your screen picture with the red circled button I realized that I did not even notice that row of options there. Apparently I had my selection set on the "Figures" button and that is why I did not see any clothing.  This is a case of a picture is worth a thousand words so thanks again! Now I'm making some progress now that you have pointed out that row of button options.
