Subject: walk designer or manual
Artchitect opened this issue on Aug 16, 2011 ยท 5 posts
Artchitect posted Tue, 16 August 2011 at 12:03 AM
i do wonder which one is seen as most beneficial for making figures walk.
rokket posted Tue, 16 August 2011 at 12:32 AM
Quote - i do wonder which one is seen as most beneficial for making figures walk.
Ummmm, both. I usually tweak the walk designer, then when I have something usable, I go into the animation layers and tweak it further.
To me, doing it manually can take HOURS, and I don't really want to spend that time. But, to qualify that, I have done it manually, and the results are usually not as good as what I could do if I spend a fraction of that time doing the above process.
wolf359 posted Tue, 16 August 2011 at 10:34 AM
Agreed use the WD to quickly get the figure from point A to point B
then go and Make global Changes/ adjustments using your graph editor.
Cheers
My website
Artchitect posted Fri, 02 September 2011 at 3:43 PM
ok thanx
jaguarmma posted Sat, 03 September 2011 at 11:00 PM
I ended up doing it by manual. I got a high heel effect with walk designer. Be sure to check out all of the camera angles to make sure your model is walking normal.
