Jeff_Kraschinski opened this issue on Aug 25, 2011 · 8 posts
Jeff_Kraschinski posted Thu, 25 August 2011 at 10:27 AM
I swear I've seen something about this, but can't seem to find anything by searching.
Is there any program that will allow you to copy a morph shape from one figure to another that ISN'T compatible? For example, create a morph for V4 that shapes it to V3's shape, or Miki2, etc?
lkendall posted Thu, 25 August 2011 at 11:56 AM
It has been a while. If I recall properly try this
If both figures are supported by Wardrobe Wizard II, then:
Save a CR2 of the character with the morph injected that you want.
Convert that CR2 like a piece of conforming clothes to the figure you want to transfer the morph to, using WWII.
Use Morphing Clothes by Dimension3D to transfer the morph from the converted CR2 to a saved CR2 of the figure you want to get the morph. Or, save it as an injection morph from Morphing Cloths for the figure you want to use the morph with.
Try out the morph. Some morphs look great, some do not. Generally the morph will not look good at high dial values.
lmk
triangle2010 posted Thu, 25 August 2011 at 9:38 PM
jeff,if I understand your question correctly, you want to copy a morph from a v4 character to a v3 character, or reverse, am I right?:b_confused:
I don't think there are any program can do that.
amandagirl15701 posted Thu, 25 August 2011 at 9:48 PM
Attached Link: http://www.the.cage.page.phantom3d.net/TDMT_Match/TDMT.html
Cage made this script that kinda' transfers face morphs from one figure to another. Is this what you were looking for?lkendall posted Thu, 25 August 2011 at 10:11 PM
With the above method I have copied V2 morphs to V4, and M2 morphs to M4.
lmk
amandagirl15701 posted Thu, 25 August 2011 at 10:39 PM
I believe you a right. After rereading the OP's question, I have to agree that WW II and Morphing Clothes is the way to go on this one. I really need to get new glasses.:blushing:
lkendall posted Fri, 26 August 2011 at 5:26 AM
For face morphs, a process like Cage's would have to be used. Unless there is a change for P9/PP2012, WWII does not transfer facial morphs, just body morphs.
lmk
amandagirl15701 posted Fri, 26 August 2011 at 9:31 PM
Attached Link: Genesis Generation 4
I noticed the OP purchased the new script from D3D and was hoping for an equivilent script for other characters. As far as I know there is no 1 click solution.
