3DFineries opened this issue on Aug 28, 2011 · 10 posts
3DFineries posted Sun, 28 August 2011 at 1:20 PM
Hi all,
I'm curious about the headpiece on Salome. I've yet to get it but am really leaning toward buying it (even if it has a morph issue) but I'd like to know two things before I take the plunge.
Is the hair part of the headpiece?
If yes, can you turn the headpiece off so you just get the hair & vice/versa?
Thanks ahead of time!
Lynn
Have a creative day!
hemi426 posted Sun, 28 August 2011 at 2:44 PM
I don't own Salome, but if it's one part you can go use the grouping tool to select a material (for example the headpiece) and turn this into a separate prop. I do these quite often and it works quite good...
3DFineries posted Sun, 28 August 2011 at 3:10 PM
Quote - I don't own Salome, but if it's one part you can go use the grouping tool to select a material (for example the headpiece) and turn this into a separate prop. I do these quite often and it works quite good...
If worse comes to worse, I could try that trick. :) I forgot about that option, thanks for reminding me. :D
Acadia posted Sun, 28 August 2011 at 5:50 PM
I have this product. I haven't used it yet. But I'll have a look once the render that I'm running is done.
say." - Ghandi
Acadia posted Sun, 28 August 2011 at 5:55 PM
I just had a look at the editorial page. It states that there are options to turn off the bangs and shoulders. And in the Readme it shows that there are "bangs on/off" and
"shoulders on/off" morphs.
So the answer to being able to turn off the entire head of hair, is no. But you can hide the bangs and shoulders of the hair.
If you like, I can still open the product up in Poser and double check for you.
say." - Ghandi
3DFineries posted Sun, 28 August 2011 at 6:00 PM
Quote - I just had a look at the editorial page. It states that there are options to turn off the bangs and shoulders. And in the Readme it shows that there are "bangs on/off" and
"shoulders on/off" morphs.So the answer to being able to turn off the entire head of hair, is no. But you can hide the bangs and shoulders of the hair.
I'd appreciate it if you could open it up for me. I'm just wondering if I can turn off the headpiece & see just the hair. If not, I'll decide what to do. I just may get it & rework it if I must. :)
Acadia posted Sun, 28 August 2011 at 6:04 PM
Ok I'll have a look for you. If there isn't, you might be able to make a transmap to hide the headpiece entirely. I'm not so good at that stuff, but I'll have a look at the texture template and see if I can figure out if a transmap might be possible.
say." - Ghandi
3DFineries posted Sun, 28 August 2011 at 6:19 PM
Thanks Acadia. Appreciate it. I was thinking of that as an option as well. Stitch Witch makes some things really easy to do. :) It may be tedious to hide all the parts with trans, but if the hair is fully modeled underneath then it'll work.
Acadia posted Sun, 28 August 2011 at 7:24 PM
Ok. I opened the head piece in Poser and there is a hide bangs, shoulders and veil. But no way to hide the headpiece itself.
I looked at the textures and it doesn't look like the hair is fully modeled. It looks like it is part of the head piece itself.
However, like I said, I'm not very good at reading more than the very basic texture map, so you might want to contact Val3dArt just to make sure.
say." - Ghandi
3DFineries posted Mon, 29 August 2011 at 5:17 AM
Thanks Acadia! I kind of thought that might be the case. I appreciate all your help. :)
