Subject: Problem With Reflection
Acadia opened this issue on Aug 28, 2011 · 12 posts
Acadia posted Sun, 28 August 2011 at 8:14 PM
I'm having an interesting problem with reflection.  The figure has hair, but the hair isn't reflecting in the back prop, but the rest of the figure does.  The figure appears completely bald in the reflection.  Here is a part of the final render.  I'll post my material room settings and render settings in the next couple of posts.
I use Windows XP Pro with current updates, and Poser 6 SR3. My Poser is set to "inches"
PS: don't worry about the freaky black areas on the figure. I don't know what that is all about, but I fixed it in post work.
Acadia posted Sun, 28 August 2011 at 8:18 PM
Render settings.
Acadia posted Sun, 28 August 2011 at 8:19 PM
Material Room
RobynsVeil posted Sun, 28 August 2011 at 8:29 PM
Quick, switch off that Refl_lite_Mult before BB catches you, Linda... :lol:
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
millighost posted Sun, 28 August 2011 at 8:29 PM
Also check if "Visible in Raytracing" is on for the hair in the object's Properties panel. This is not a material setting, but an object setting. It might be off.
Acadia posted Sun, 28 August 2011 at 8:31 PM
Thanks to both of you!
hides the lit_mult thingy!!!  lol
Acadia posted Sun, 28 August 2011 at 8:33 PM
Quote - Also check if "Visible in Raytracing" is on for the hair in the object's Properties panel. This is not a material setting, but an object setting. It might be off.
It wasn't checked!  I've checked it and will try another render.  Hopefully that and unchecking "lit_mlt" will do the job :)
RobynsVeil posted Sun, 28 August 2011 at 8:40 PM
Oh! Didn't realise that for hair reflections to show up the Visible in Raytracing had to be ticked... I thought that was just a shadows thing...
Metaphor of Chooks
bagginsbill posted Mon, 29 August 2011 at 9:05 AM
Reflection, refraction, AO, IDL, and ray-traced shadows, all are ray-traced effects.
Invisible to ray-tracing means that those polygons are not in the scene (equivalent to deleted) when the ray-tracer does its things.
Daymond42 posted Mon, 29 August 2011 at 10:37 AM
Hell, I was not even aware of that option! That makes the concept of rendering scene with a vampire and a mirror even more fun to do..
runs off to experiment
Currently using Poser Pro 2012 (Display Units = feet)
AMD Phenom II 3.2ghz (6 cores)
8gb RAM
Windows 10 Pro 64bit
Acadia posted Mon, 29 August 2011 at 1:10 PM
Thanks everyone!  It worked like a charm. And unchecking that "lit_mlt" made the reflection even better.  I usually do uncheck it (I did for the floor), but overlooked it for the back prop.
RobynsVeil posted Mon, 29 August 2011 at 5:30 PM
Quote - Reflection, refraction, AO, IDL, and ray-traced shadows, all are ray-traced effects. Invisible to ray-tracing means that those polygons are not in the scene (equivalent to deleted) when the ray-tracer does its things.
Makes sense, of couse, when you put it that way... no clue why that didn't occur to me. That will explain the dead hair I've been getting in my renders. Oh well, render time will just have to increase. Gives me more time to get that second load of washing folded... :biggrin:
Metaphor of Chooks
