divingbuddah opened this issue on Aug 30, 2011 · 4 posts
divingbuddah posted Tue, 30 August 2011 at 9:35 PM
I what to make some short animations and stills of exercises using resistance tubes and cable pulls.
Both ends of the tube need to be fixed, one end to a tie off the other to the figure's body somewhere. How can a prop be made to adjust when both 'fixed' ends vary in their relationships with each?
FYI if the cloth room is the solution, I need step by step help since I am a cloth room virgin.
thanks for any ideas.
geep posted Tue, 30 August 2011 at 9:46 PM
Would something like this work?
It could be used for linear motion, i.e. rubber band stretch, as well as radial motion.
cheers
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
markschum posted Tue, 30 August 2011 at 10:18 PM
you can make a prop morph for the short and long positions. That could even be done in Poser with magnets and then spawn a morph from it. It would depend on how many positions you would need. A figure with handle-spring-handle would be easy to make.
Miss Nancy posted Wed, 31 August 2011 at 12:01 AM
those things may be the kind of elastic tubes that get thinner as they stretch. like extra-large latex surgical tubing. they can't use springs, as they pinch yer skin if yer not careful.
