shorterbus opened this issue on Sep 15, 2011 · 7 posts
shorterbus posted Thu, 15 September 2011 at 3:33 PM
Poser 8, Windows 7.
Somehow I managed to change the size of my docked document window and now it runs of the right edge of the monitor and I can't change it back. I can undock it, adjust the size, but then when I dock it goes off the screen again. Help me, Obiwan!
vilters posted Thu, 15 September 2011 at 5:16 PM
Start Poser
Goto Edit
Goto General Preferences
Goto Interface
Select Launch to factory state
Save
Close Poser
Restart Poser
Your Interface should be at factory state again.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
JunkoH posted Thu, 15 September 2011 at 5:25 PM
you just need to check "floating" on document window. that way it won't dock and will stay the size you set it for
shorterbus posted Thu, 15 September 2011 at 5:29 PM
Vilters, thanks for the suggestion, it makes sense, and it was one of the fifty or so things I tried before coming to the forums. Unfortunately, it didn't work.
May if I approach the question from a different angle - how do I set the size of a docked window?
millighost posted Thu, 15 September 2011 at 5:36 PM
After you remove the file:
c:/users/millighost/Application Data/Poser/8.0/English/Poser UI Prefs_1280x1024.xml
(username and screensize can vary) the settings are reset after a restart of poser. If you feel experimental, you can also poke around in that file, the window geometries are somewhere in it.
seachnasaigh posted Thu, 15 September 2011 at 10:19 PM
Look for the icon (which looks like a barber pole, or maybe it's a piece of braided rope, or a screw jack) along the border of the window. Click on it and drag it leftward.
OSes: Win7Prox64, Win7Ultx64
shorterbus posted Fri, 16 September 2011 at 8:46 AM
Sorry, got called away for work. I'm off to try thee suggestions. THanks!
