attilako opened this issue on Sep 16, 2011 · 8 posts
attilako posted Fri, 16 September 2011 at 3:16 AM
All my poser characters have Eyes internal name: rightEye leftEye. But one figure has lEye rEye internal names.
I edited the cr2 file and changed all the rEye to rightEye and lEye to leftEye, but then the eyes disappeared.
Is there any solution to this?
Thanks
David.J.Harmon posted Fri, 16 September 2011 at 3:36 AM
which MOD?
David J Harmon
davidjharmon.com
cspear posted Fri, 16 September 2011 at 3:47 AM
Quote - I edited the cr2 file and changed all the rEye to rightEye and lEye to leftEye, but then the eyes disappeared.
Use the backup copy - you know, the one you made in case anything went wrong.
PoserPro 11 - Units: Metres
Adobe CC 2017
chriscox posted Fri, 16 September 2011 at 4:44 AM
The internal names in the CR2 need to be the same as the group names in the OBJ file. So if you want to change the internal names in the CR2 you you need to also change the corrisponding group names in the OBJ file as well.
MacMyers posted Fri, 16 September 2011 at 5:36 AM
I'll never understand this stuff.
“So, roll me further B_t__h!”
attilako posted Sat, 17 September 2011 at 3:06 AM
"The internal names in the CR2 need to be the same as the group names in the OBJ file"
That's right, I found the internal names in the OBJ file!
Thank you
SamTherapy posted Sat, 17 September 2011 at 4:52 AM
Why would you want to rename them?
attilako posted Sat, 17 September 2011 at 6:16 AM
because when I insert the animation from the other figures with eyes moving then this special character's eyes will also move.
