Ninja-G33k opened this issue on Sep 17, 2011 · 4 posts
Ninja-G33k posted Sat, 17 September 2011 at 12:06 AM
I have a 30-day trial period for Morph Loader Advanced and Morph Loader Pro in DS 4.0.2.55 Standard (32-bit). Unfortunately, I can get neither plugin to work.
I have some old morphs (OBJ files) that loaded just fine when I was using the Morph Loader plugin for DS 2.3, but in DS 4 I just get a "One or more of the files loaded had no effect" message when I try to use Morph Loader Advanced, and Morph Loader Pro tells me that the morph imported successfully, but when I look at the Parameters tab the morph is nowhere to be found.
I suspect this boils down to User Error™, but I'm baffled as to how to solve the problem.
Any help is greatly appreciated.
TheHalfdragon posted Sat, 17 September 2011 at 12:21 AM
you may find the dials and that for the putting the morphs in either the shaping section or the parameters section ninja. those would be the first two places to look as morph loader doesn't apply them it just makes them available for you to dial in
Ninja-G33k posted Sat, 17 September 2011 at 12:43 AM
Quote - you may find the dials and that for the putting the morphs in either the shaping section or the parameters section ninja. those would be the first two places to look as morph loader doesn't apply them it just makes them available for you to dial in
Thanks for the reply! Those tabs were the first places I looked.
TheHalfdragon posted Sat, 17 September 2011 at 1:15 AM
damn then i dunno that's where i look when i use the ds3a version
