Forum: DAZ|Studio
Subject: Problem importing Poser file in DazStudio 4 pro updated
martial opened this issue on Sep 17, 2011 · 14 posts
martial posted Sat, 17 September 2011 at 6:09 AM
Bonjour
I have updated yesterday to version 4.0.2.55 pro (64 bits)
I have tried to import Poser file (Victoria 4,2 file .pzz and .pz3 format) Nothing appears in is in the scene No importing
I have tried differents poser files :nothing is imported no error message just nothing in the scene
It was ok with last version (4.0.2.35):i have imported many Poser files with succes not in the new update
i also tried with 32 bits version (updated one) :same problem
Someone have the same problem??
Thanks
martial posted Sat, 17 September 2011 at 11:11 AM
Precision:
Each time i try to import a scene with V4 character ,only the ground and the light are imported
Another user report the same problem on Daz forum
datastorm posted Tue, 20 September 2011 at 6:32 PM
Me too,
I have Daz studio 4 advance also using poser 8, only work around that I
found is to take my characer and put it into the character library then goto
Daz studio and bring it in that way
martial posted Tue, 20 September 2011 at 7:04 PM
I hope that DAz correct this as soon as possible
Thank for your trick (but it is a temporary solution)
The first version was ok
I have triy to put a ticket at support for it  but my browser crash each time i try (don't know why) Hope someone do it
Elliandra posted Sat, 24 September 2011 at 10:55 AM
Hello,
If I might ask if you changed any of your library/directory settings when you Installed 2.55? I'm running the 64-bit version as well and I've had this happen when I moved some files but it usually pops up an error, if not in the popup window then in the log file.
You can access the log file via the "Help : TroubleShooting : View Log File" from the main toolbar in DS. That might help to pin down what is causing the error with your file loading. If it mentions being unable to find .dso files or some such thing the method below should fix it for you.
A good way to get .daz files from previous builds to work if they are not is to setup the figure/prop whatever it is that's not showing up in the scene in DS with whatever morphs you need applied, or just injected, and then save that out as a scene that you can delete the .daz file for when you are done. When you save a .daz file it converts all the information to .dso format and saves it in the data folder (usually in your main DAZ Studio folder). This should then allow you to open the .daz scene that was giving you trouble before and have everything load in as it's supposed to.
I hope this helps you if not just holler!
Elliandra
Inspiration is like the faintest wisp of an illusive fragrance, soaring out of reach until you think you have lost it when suddenly it reappears out of nowhere to fill your mind and soul with such an intensity that it consumes you....
martial posted Sat, 24 September 2011 at 12:48 PM
Thanks for reply
the problem is not with .daz file or .dso
it is with pzz or pz3
see what  the log file display
''Importing v4 base daniece morphs danae texture pw rebecca cloth.pzz ...
Time to load file: 21.4446 ms
Failed to import: F:/3ddata2/Poser 8 2010/V4/v4 base daniece morphs danae texture pw rebecca cloth.pzz
Operation failed
Building Scene... ''
nOTE That the first version of DS4 importing the same file without problem
the problem coming with update
and someone elf at daz forum meet the same problem
Elliandra posted Sat, 24 September 2011 at 1:36 PM
Could it maybe be the spaces in the file name? I don't use Poser much so not sure but it's an idea...
Elli
martial posted Sat, 24 September 2011 at 2:33 PM
thanks Elliandra
I receive your message by site mail and send you a reply
Elliandra posted Sat, 24 September 2011 at 9:43 PM
Bug Report posted for you!
https://bugs.daz3d.com/view.php?id=43966
hugs
Elli
martial posted Sun, 25 September 2011 at 4:35 AM
THanks
i will follow it....
martial posted Fri, 30 September 2011 at 1:06 PM
Still no feedback from DAZ
Elliandra posted Sat, 01 October 2011 at 1:57 PM
Hey Martial!
I heard from the gentleman who was assigned to test the bug and he confirmed that he is able to reproduce it so afaik it is now with the team who goes into the coding etc to track down what's causing it.
hugs
Elli
martial posted Sat, 01 October 2011 at 2:26 PM
Merci beaucoup pour ton aide
Thanks for your attention to my problem
Elliandra posted Mon, 03 October 2011 at 1:48 PM
You are most welcome Martial!
hugs
Elli
