Forum: Freestuff
Subject: Decorative Wooden Tissue Box
3dcheapskate opened this issue on Sep 27, 2011 ยท 2 posts
3dcheapskate posted Tue, 27 September 2011 at 8:49 PM
Freshly uploaded to [ Renderosity Freestuff](http://www.renderosity.com/mod/freestuff/details.php?item_id=65809) and [ ShareCG](http://www.renderosity.com/mod/forumpro/=http:/www.sharecg.com/v/55471/gallery/11/Poser/Decorative-Wooden-Tissue-Box) on 27 Sep 2011.
A simple model of a decorative wooden tissue box. It's a two-part prop, with a separate sliding base. There are four separate pp2 files so you can load either the box without a base, the sliding base only, the box and base together (base parented to box), or a one-piece closed box. The base loads so that it's in the fully closed position if you also load the body. All variants load with the box sitting on the origin. The box is about the size of a standard Poser figure's hand.
A DS materials preset is included to give a similar appearance to the Poser renders.
The whole thing's been tested in DAZ Studio 3 and Poser 6 with no real problems, but see the readme.
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate posted Tue, 27 September 2011 at 8:53 PM
...and a few sample renders in Poser 6, DAZ|Studio, and LuxRender...
