Subject: Ugly preview screen and renders in Poserpro2012
brewgirlca opened this issue on Oct 04, 2011 · 73 posts
brewgirlca posted Tue, 04 October 2011 at 9:42 PM
Looking for setting fixes in poserpro2012 to solve ugly screen problem.
I am getteing really flat and dull grayish preview screens in my poserpro2012. And the renders look much like the preview screen - flat and gray - none of the great color depth I was promised.
I have poserpro2010 on the same system and its preview looks light, bright and colorfull, just like poser 7 on my old machine. So I don't think it is my video card or system hardware and software because poserpro2010 is working fine on it.
A friend just sent me a site telling me to turn off the gamma correction in the render screen and that seems to have fixed the guts of the render problem. She also said to turn off SSS but isn't that a major reason for going with this upgrade? Anyways I may have the render issue resolved but the preview screen still looks so darn ugly compared to poserpro2010 and poser 7 I just don't think I can bring myself to work with it.
Also notice how the eyes in my preview screen for pp2012 look glassy, like elven eyes. They render ok but just don't show in preview.
Ok, so any ideas on how I can make some setting changes to get my preview screen looking pretty again and to fix those glassy eyes?
I attach here shots of the preview screen for all three versions of poser and the renders (before I made the fixes on the gamma correction for poserpro2010 and pp2012 so they still look ugly here - but it may help someone recognize a similar problem on their system.)
The file I used was made in poser 7 and then imported into both pp2010 and pp2012. The lights were identical in all three - they were from a simple DM set of 3 lights that I imported with no changes. I get the same dull look on raw files I create right in pp2012 so it is not importing from poser 7 that is causing the problem.
basicwiz posted Tue, 04 October 2011 at 10:25 PM
Just a suggestion...
If turning off gamma control seems to make the issue better, do two things.
First, go through the setup and accurately set your gamma for your video card and screen. DO NOT just set things up so they look the way you think looks right... I promise you they are not right. Use the setup software that came with the video card, or go to a gamma set screen (Google it) and set the gamma up right on your screen.
Second, go to Scripts -> Partners -> Image Gamma and run that script on everything in your scene. It seems to resolve some odd things that happen with a fiew of the pieces I use.
See if this doesn't give better results. It took me a little while to realize that the super-saturated colors I was accustomed to were not actually all that realistic! Once I got all of this set up right, along with the improvements in the render engine, Gamma works for me. (And if you check my history here in the threads, I was one of the main rabble rousers against GC prior to PP2012!)
Good luck.
bantha posted Tue, 04 October 2011 at 11:31 PM
The preview is different now, that's for sure. The new Poser versions use shaders not just for rendereing, but also for the preview. That's why it looks different, the old preview used just the texture but not the nodes. Your models eyes look glassy because they have glassy shaders. I find the new preview mode better than the old one, because I can spot more problems before rendering, but I fully understand that you will have to get used to it first.
About gamma correction - learn to use it right and you will get more realistic renders. Without gc you will need much to much light for your scenes, and that will show. Search for BagginsBills postings about gc to get some explanations. If you rerender a scene from Poser 7, which does not have gc in Poser 2012, you will have to redo the lights, because gc makes them stronger, though. Learn to use the new features!
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
wimvdb posted Wed, 05 October 2011 at 2:13 AM
There are a couple of things which are different between PP2012 and previous versions.
bagginsbill posted Wed, 05 October 2011 at 7:00 AM
Also the most common style of shader, from Daz for V4 and M4 figures, has fake subsurface scatter and fake gamma compensation built into them. Part of this involves a blue tint to the diffuse color, and a red tint added back based on lighting brightness.
This style of shader is ugly and wrong when you enable real GC.  If you feel you must just stay out of the material room and you have to use older purchased content at all times, with no changes, then you will want to disable GC. However, you will not be able to produce the stunning new realistic skin that PP2012 is capable of. In which case, you might as well not have it. If you're going to render that way, I'd send it back for a refund.
bagginsbill posted Wed, 05 October 2011 at 7:02 AM
Can you do this? If not, go read how at RDNA.
ssteph posted Wed, 05 October 2011 at 8:37 AM
Quote - Can you do this? If not, go read how at RDNA.
Do you have the link pleeeeze?
or name of the thread?
Thankers
bagginsbill posted Wed, 05 October 2011 at 9:38 AM
Quote - > Quote - Can you do this? If not, go read how at RDNA.
Thankers
Sure. The thread you want is:
http://www.runtimedna.com/forum/showthread.php?64789-Which-node-SubsurfaceSkin-or-Scatter-Blinn
On page two, I posted the screen shots (post #30) of the material setups used in the comparison renders, and right after that (post #31) I posted the actual Poser material file which you can directly download.
EDITED: Note that I posted a corrected version of the material on page 3, post #42. The corrected one is more friendly for VSS.
nobodyinparticular posted Wed, 05 October 2011 at 12:54 PM
Thank you bagginsbill. I found that turning GC down to 1 gets at least acceptable results with M4, V4, and K4. Now I can get it right.
ssteph posted Wed, 05 October 2011 at 1:03 PM
Thanks BB I'll try and absorb all that tomorrow...
not sure my pea brain can handle it though....lol
Quote - > Quote - > Quote - Can you do this? If not, go read how at RDNA.
Thankers
bagginsbill posted Wed, 05 October 2011 at 2:06 PM
Quote - Thank you bagginsbill. I found that turning GC down to 1 gets at least acceptable results with M4, V4, and K4. Now I can get it right.
What are you saying? Turning GC to 1 is exactly the same as NO GAMMA CORRECTION. A gamma of 1.0 means a straight line, linear, exactly NOT how monitors and digital images work.
RodS posted Wed, 05 October 2011 at 5:05 PM
I just sitemailed you, Roxy - dang..... shoulda jumped in here first.
Aside from being knocked right out of my chair by BB's render above, I can see I have a lot to (re)learn... Great info here!
I did notice the blue color in diffuse that BB alluded to. Making this white, or slightly warm makes the skin pop without turning off SSS.
Now, I'm gonna go play with the gamma setup..
"I reject your reality and substitute my own" - Adam Savage
FightingWolf posted Wed, 05 October 2011 at 5:09 PM
Quote - Looking for setting fixes in poserpro2012 to solve ugly screen problem.
I would agree with basic wiz on this one when it comes to rendering.  From what I can tell Gamma is washing alot of the color out in the rendering.  Definitely make sure your monitor is actually displaying colors correctly.
The Poser 2012 preview lighting also looks different. I'm almost willing to say that one of the lights is malfunctioning. One way to check is to copy the cordinates for the light and then move the light to see if the light becomes brighter.  There just seems to be way too much shadow in that Poser 2012 render for the light to be working properly.  Sometimes the lighting in Poser doesn't function the way that it should and moving the bad light causes it to shine properly.  I don't know why it happens, I just know that I had that issue with Poser Pro 2010.
if all else fails or "try it first" then change the Preview Drawing (in the Display Menu) to SreeD Software.  It won't help your rendering issues but it will definitely help your preview issues.
brewgirlca posted Wed, 05 October 2011 at 8:06 PM
Bagginsbill, you have given us some super good information here that will help us tremendously. Big thank you for your detailed responses.
But I can assure you that turning the GC down to 1.0 is significantly different than turning GC off. I have now done renders now with GC off, GC at 1.0 and GC at the default 2.4 or thereabouts. And the 1.0 is much richer than the default setting and it is not as rich/bright as turning GC off. And the preview screen looks way better with the CG turned down.
brewgirlca posted Wed, 05 October 2011 at 8:46 PM
Fighting Wolf:
Thanks for the tip on ScreeD. Indeed it makes a significant difference. Especially now I do not get glassy elven eyes in preview. However, adjusting the gamma correction down to 1.0 has made the preview much better.
However, it is not the right answer about the monitor settings. I am using the same computer sytem and monitor for both poserpro2010 and poserpro2012 and the render results for poserpro2010 were much richer. However, the gamma correciton adjustment has given much better results for both the preview and for the renders.
I too suspect that there is a wonky light affect going on in poserpro2012.
However, ultimately I think the problem is gonna turn out to be a bug in the openGL hardware... just my uneducated guess.
kawecki posted Wed, 05 October 2011 at 9:15 PM
My new LED monitor has three gammas, gamma 1, gamma 2 and gamma3, which one have I to use?
Stupidity also evolves!
bagginsbill posted Wed, 05 October 2011 at 9:15 PM
Quote - Bagginsbill, you have given us some super good information here that will help us tremendously. Big thank you for your detailed responses.
And I can turn around and assure you that x to the power 1 is just x.
The gamma function is raising the number to a power. Gamma 2.2 is x ^ (1/2.2). Gamma 1.5 is x ^ (1/1.5). Gamma 1 is x ^ (1/1) which is x ^ 1 which is just x. "Just x" is identical (the definition of) not doing gamma correction.
Nevertheless, I considered the unlikelihood that you'd want to challenge me on the subject of gamma correction unless you had evidence. Perhaps Poser Pro 2012 has a bug. So I loaded numerous scenes of many different lighting setups, and rendered with GC off, and also GC = 1.
I do not find any differences. All the images are identical. I have now wasted half an hour demonstrating what I already know from years of experience with gamma.
So - if you can actually reproduce your differing outcomes, and show me the difference, that would be helpful. It would serve no purpose for me to show you 20 pairs of identical renders as proof that there is no difference. It is not possible to prove something doesn't exist by showing examples of its absence. Maybe there's a scenario I simply did not run into, and there really may be a bug I have not encountered. The only resolution is to show me a difference in two renders, perhaps in a scene we shared, where the outcome is different and the only difference is that one render setting; GC off versus GC = 1.
Or for you to realize that you changed two things and assumed that the other thing was unimportant, and only the GC mattered.
I'm not speaking of preview here - just renders. Although I have to say that I can't find a difference in preview either.
Also, 2.4 is not the default. It is 2.2. The gamma of sRGB images is 2.2.
bagginsbill posted Wed, 05 October 2011 at 9:31 PM
I'm going to post three renders. Among these the only difference is GC. One will have GC off, one will have GC=1, and one will have GC=2.2.
You tell me which is which.
A
B
bagginsbill posted Wed, 05 October 2011 at 9:32 PM
C
bagginsbill posted Wed, 05 October 2011 at 9:34 PM
Two of these look not quite identical (individual pixel differences) although the luminance is the same overall - the reason is that IDL is semi-random and produces tiny differences from one render to the next, even with all settings identical.
So - which is which and how do you know?
bagginsbill posted Wed, 05 October 2011 at 9:38 PM
When you do a flip-comparison of a render with and without GC, it looks like an additional light is being turned on and off.
So - imagine you are refining a scene. You add lights until it is just right.
Then you add one more light - and you decide that is wrong, and you remove it.
Then years later you get Poser Pro and you render with GC on. It looks like you added a light and again you conclude it is wrong.
But instead of removing some of the light because now there is too many or too much, you decide to not use GC and tell other people it washes out your pictures.
Huh?
Lights wash out your picture, too, when you add too many. Do you tell people not to use lights?
kawecki posted Wed, 05 October 2011 at 9:40 PM
If gamma off and gamma 1 are the same thing, why these three images are different and not only two
bagginsbill posted Wed, 05 October 2011 at 9:57 PM
I already answered that.
bagginsbill posted Wed, 05 October 2011 at 10:00 PM
I'm not reacting to tiny differences or responding to tiny differences. I'm reacting to this:
Quote - But I can assure you that turning the GC down to 1.0 is significantly different than turning GC off
Signficantly different. As in, you should be able to tell me which is GC=off and which is GC=1.0. Which is it?
stallion posted Wed, 05 October 2011 at 10:02 PM
one of these things is not like the other, can you tell me which thing don't belong....I remember that game from The Electric Company..
render A do not look like render B or C
You might as well PAY attention, because you can't afford FREE speech
FightingWolf posted Wed, 05 October 2011 at 10:31 PM
Quote - Lights wash out your picture, too, when you add too many. Do you tell people not to use lights?
 LOL yeah I do ha ha ha. Well not exactly.  I just tell them not to over do the scene with lights, by trying to keep things to as close to 3 lights as possible (not talking about lighting in a light dome or prop lighting.  The "3 light rule" applies to the portraits.
What I've noticed (from abusing gamma) is that the Gamma Correct is only part of the equation.  The gamma settings on the materials will play a big part on how different a Gamma Correction of 1 will be.  For the majority of the character textures that I have a Gamma Correction of 1 with no material gamma changes will usually give me the "same" render that I would get with Gamma Correction off.   If I change the materials gamma and try to use the same Gamma Correction of 1 then I get a really big difference than before.  I usually end up with characters that look severely sun burned, or fire burned.  Not trying to explain anything just sharing what I've noticed when playing with Gamma.
The one thing Poser Pro 2012 does right away when it comes to Gamma Correction is that it forces the user to deal with the gamma settings of the materials.  I have yet to be able to use Gamma Correction without adjusting something gamma in the Materials.  For me it's not enough to just change the Gamma Correction.
bagginsbill posted Wed, 05 October 2011 at 10:36 PM
Quote - If I change the materials gamma and try to use the same Gamma Correction of 1 then I get a really big difference than before.
But that means you're not using gamma = 1 on the image then. Which means the incoming gamma anti-correction is turned on (because you enabled GC) but it is not 1.
Come on you know very well that if the gamma is not 1, you can't say it is 1.
In that case, GC=Off means gamma = 1 no matter what you typed anywhere, and GC=On (any value) means you have a gamma on an image that is NOT 1 if you didn't type 1. Any override of the number that isn't one, with GC enabled, means it is not Gamma=1. It is whatever number you typed.
Well, duh.
Quote -  For the majority of the character textures that I have a Gamma Correction of 1 with no material gamma changes will usually give me the "same" render that I would get with Gamma Correction off.
Not majority - ALL.
Not usually - ALWAYS.
If you have gamma = 1 incoming and outgoing, then gamma = off is no different. Ever.
FightingWolf posted Wed, 05 October 2011 at 11:12 PM
Quote - But that means you're not using gamma = 1 on the image then. Which means the incoming gamma anti-correction is turned on (because you enabled GC) but it is not 1. Come on you know very well that if the gamma is not 1, you can't say it is 1.
I'm not referring to the actual Gamma.  I'm referring to the render setting where you type 1 into the Gamma Correction setting.  I understand that if Gamma is applied to the material then typing 1 in the Gamma Correction setting doesn't mean that Gamma is 1.
But someone that isn't familiar with Gamma Correction and gamma applied to materials will easily think that the Gamma is 1, because that's what's typed in the Gamma Correction box.
For you Gamma is like breathing but for many others from Poser 1 to Poser 7 gamma doesn't come into play on their end, which is why you get such a headache explaining it.  Some users will only see Gamma Correction and never realize that they can actually set the gamma for their materials.
bagginsbill posted Wed, 05 October 2011 at 11:52 PM
Quote - But someone that isn't familiar with Gamma Correction and gamma applied to materials will easily think that the Gamma is 1, because that's what's typed in the Gamma Correction box.
But if they never realize they can do that, then they must not be doing that. You don't go setting image gamma by accident. It's hard to do.
My point is, I made the assumption that since brewgirlca said gamma=1, she meant gamma=1. If she made gamma=1 in render settings, and she never, ever went into the material room and changed the individual gamma on one of the color maps to something other than 1 or "Use Render Setting", then gamma is 1 as claimed, and there can be no difference.
If, despite saying gamma=1, she has manually altered an image gamma value so that it does not equal 1, then gamma does not equal 1 anymore and there's nothing to refute. The difference in gamma is produced by enabling gamma, causing the specified value that is not 1 to be used.
Is it possible she altered the gamma on an image, but was not aware of doing so? Perhaps - which is why I said, in my first response to the issue, "Or for you to realize that you changed two things and assumed that the other thing was unimportant"
kawecki posted Thu, 06 October 2011 at 12:24 AM
Quote - I already answered that.
Quote - Two of these look not quite identical (individual pixel differences) although the luminance is the same overall - the reason is that IDL is semi-random and produces tiny differences from one render to the next, even with all settings identical.
That it means that every rendering that I make will be different and never can be repeated ? I am speaking about perceptible differences, because your example B doesn't look the same as example C. B has some color and C looks more black and white.
brewgirlca posted Thu, 06 October 2011 at 12:27 AM
Well Bill, since as you say it is unlikely that I'd want to challenge *you* on the subject of gamma correction unless I had evidence it is clearly necessary to provide such. Maybe your just having a bad day so given your rather defensive response in regards to my statement of significant differences between Gamma Correction 1.0 and Gamma Correction 0.0 I will not waste your time making you guess which is which. I will simply tell you the answer and let others see for themselves that 1.0 is not equal to 0.0, all theory aside.
Three back to back render images, gamma correction off=0.0, gamma correction 1.0 and gamma correction 2.2. No other changes in render or material room between renders. Render window to follow.
Can you people honestly not see a significant difference between 0.0 and 1.0 even in this much reduced upload? And please don't tell me it's random fluctuation. It isn't. It happens agains and again but I will not waste my time showing you a dozen renders to prove it.
brewgirlca posted Thu, 06 October 2011 at 12:28 AM
Render window for gamma test.
kawecki posted Thu, 06 October 2011 at 12:35 AM
Quote - Three back to back render images, gamma correction off=0.0, gamma correction 1.0 and gamma correction 2.2. No other changes in render or material room between renders. Render window to follow.
You just achieved exactly the same result as the BB examples, all three images are different.
Gamma 0.0 has color, gamma 1.0 is more in black and white and gamma 2.2 produce a washed and dull image typical with using gamma correction.
PS; Your best image is with gamma 0.0
Khai-J-Bach posted Thu, 06 October 2011 at 12:41 AM
rolls eyes
and the Gamma War carries on.
brewgirlca posted Thu, 06 October 2011 at 12:48 AM
That's what I am saying Kawecki. Bill says 0=1 but 2.2 is different.
I am saying 0 is not equal to 1 and will produce a different render. So he says 2 of the images will be the same and 2.2 will be different. I am saying that all 3 will be different. You can clearly see that too?
brewgirlca posted Thu, 06 October 2011 at 1:01 AM
And just to show that I did set Gamma Correction to 1.0 in the render window here it is. And I could have done so in the material room as well but I did not because we are discussing the render window.
Maybe there is a bug and some peoples versions of poserpro2012 are behaving somewhat differently. Some people say they have beautiful preview screens - mine looked like crap until I fiddled with gamma. Others have reported similar.
FightingWolf posted Thu, 06 October 2011 at 1:02 AM
Quote - PS; Your best image is with gamma 0.0
If gamma changes are made to the skin through the Image Gamma script then it'll be possible to improve changes with the Gamma Correction setting of 2.2.  It won't be washed out  it will actually bring out more skin detail with some skin textures.  It'll be like getting two skin textures for the price of one. It's that much of a difference.  I'm not a big fan of realism so I use gamma in a different way, but I've seen how the correct gamma settings have improved the realism on some of my older textures that were created back in the early days of Aiko 3.
brewgirlca posted Thu, 06 October 2011 at 1:06 AM
Believable:
My tone mapping is set to none.
I would not be surprised if there was a bug here then given what you say.
Believable3D posted Thu, 06 October 2011 at 1:10 AM
Quote - Believable:
Yeah, I just realized that. Your image made the option look active at the numberset, but I just noticed that the dropdown was set to none.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
Believable3D posted Thu, 06 October 2011 at 1:17 AM
Waitaminute! Let's clarify something: When you say GC=0, do you mean: OFF? or do you mean: ON, but set to 0? (That is NOT off.) That is just taking GC in the opposite direction.
(Honestly, I don't think that's what you're doing, 'cause when I do that, I get REALLY weird results....)
Edit: actually, when I attempt to set GC on to 0.0, it actually forces a 0.2 minimum.
______________
kawecki posted Thu, 06 October 2011 at 1:23 AM
Well, in theory a gamma of 0.0 should produce a white image where is nothing more than white every where
kawecki posted Thu, 06 October 2011 at 1:31 AM
Correction. In this case gamma 2.2 is not a power, it is the inverse or 2.2 root. The power is 1/2.2. In case of gamma 0.0 will give (RGB)^1/0.0 = INFINITE.
Believable3D posted Thu, 06 October 2011 at 1:45 AM
I think something else must be creating a conflict in your GC results.
Just ran my own test. GC=1 and GC=Off are identical (comparison render wipe = indistinguishable).
 In this instance, my GC=2.2 render definitely looks more desaturated compared to the GC=Off renders... but also far more realistic.
I do think that the relative ugliness of your GC renders is probably a materials issue... but I also think that kawecki's preference for your GC=0 render probably indicates a bias a lot of us have, i.e. that oversaturated looks better to us. In actuality, however, it certainly is not more "real."
______________
FightingWolf posted Thu, 06 October 2011 at 1:52 AM
Quote - Is it possible she altered the gamma on an image, but was not aware of doing so? Perhaps - which is why I said, in my first response to the issue, "Or for you to realize that you changed two things and assumed that the other thing was unimportant"
My guess is that the Vendor added gamma to the material already which is why there are differences in the render even when the Gamma Correction is changed.  It may also explain why someone would say they made no changes to materials, not realizing that the vendor made the changes already. Some of my character skins have gamma changes but the only way I knew was because I used the Image Gamma script. (better than hunting for nodes).  So I can see where the confusion would come from since Gamma Correction isn't the Same as the Actual Gamma.
But the first assumption for many people who aren't familiar with gamma may be to use the Gamma that Monitors (Mac vs PC) opperate at it.  I think Photographers have a better idea when it comes to gamma since it's a common edit feature for photography.
brewgirlca posted Thu, 06 October 2011 at 2:10 AM
Ok, I meant Gamma off. Which is not 0, yes, my late night mistake. Still I am getting what I am getting. And when I do render wipes I do see a difference.
Believable3D posted Thu, 06 October 2011 at 2:16 AM
Yeah, I keep wondering if there is something in the materials that gets triggered when GC is on (even if at 1). I think that's what FightingWolf is getting at.
The more Poser improves, the more I'm inclined to think that we're gonna need to revisit the materials of the old products and revamp them to deal with the state of things.
______________
kawecki posted Thu, 06 October 2011 at 2:22 AM
The problem of gamma correction is that should be applied when needed only to the dark parts of the image and not to all the image.
Even with cathode ray tubes, the old CRT monitor, the relationship between grid voltage and beam current is very non-linear near the cuttoff voltage (black level), but becomes more or less linear in the white levels.
bantha posted Thu, 06 October 2011 at 5:54 AM
Why are you using HDRI-Optimized output? I'm pretty sure that BB's test renders did not use that, could make a difference. If you export your image as HDRI then the colorspace is much bigger, and linear as well. According to the manual, this only should be switched on when you plan to use the images in .hdr or .exf formant.
Maybe the difference is here?
 And, pretty please, check if the gamma value in the textures is 1.0 as well. If you switch global gamma correction on the images files may still have an different value. If the texure was loaded with a different GC value and global GC was set to 1 you will still get a different result from switched off GC, because the image file is GC-corrected when incomin - just not when outgoing.
vilters posted Thu, 06 October 2011 at 6:48 AM
From the moment Gamma Corrction came in Pro, I only use ONE infinite light.
Rarely, but it is extremely rare, I add a (very low settings) spotlight .
Never-ever, more then 2 lights.
There is only one sun. (Iside BB's sfere this single infinite light sun at 80%)
There is only ONE main light source in a room.
But Yes, I do use ambient to make things glow.
Like a PC screen, or a TV, or a candle light, or a lightbulb.
And YES, I use BB's sfere in all my renders.
manoloz posted Thu, 06 October 2011 at 10:36 AM
Quote - There is only ONE main light source in a room.
I'm sure you mean in daytime. But still,
As an architect, I would have to refute this.
Interior scenes have commonly a LOT of light sources, and part of the magic of well designed interior spaces is having the user focus his attention depending on, among other things, lighting.
"Architecture is the masterly, correct, and magnificent play of masses brought together in light." Le Corbusier
What is also true is that it is very common to have most of interior scenes in shadow, so you need lots of lights to illuminate an interior, as walls and other elements occlude the light coming from outside. This is not usually perceptible as we unconsciously brighten scenes. We are hard-coded to perceive this way. But just walk outside in the sun and look towards he interior of an unlit building through a window. Quite dark. And if you take a picture the effect is even more pronounced.
In other words, even when we have a much more dynamic range of possible colours and luminosity perception in our eyes, we also have automatic gamma correction built in.
A gamma correction world does mean we have to take more things into account. But it also means that getting consistent, predictable results is much easier and faster in the medium and short term.
An architect's translation of Bagginsbill's gamma correction explanation :)
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
vilters posted Thu, 06 October 2011 at 10:46 AM
You are quite right.
Most objects in daily life diffuse light in interiors.
All materials are light diffusers/mirrors. (otherwise we would not see them).
In real life the dust particles in the air help in this diffusing.
Most light (during the day) comes throug the windows and gets diffused/reflected inside a room.
At night, the light from out lamps and lights has the same effect.
Believable3D posted Thu, 06 October 2011 at 12:14 PM
BUT... that is not achieved by what Poser calls "lights." No room in the world has "infinite lights." And you'll rarely see a genuine spotlight either. What should be happening is that we're creating light from glowing props, and the effect is much different than throwing a bunch of Poser lights in a scene.
______________
RodS posted Fri, 07 October 2011 at 7:04 PM
Dang, Roxy, You didn't stir the pot much, did you? :-D
OK - I see I'm gonna have to spend some quality time reading through this forum thoroughly, and doing some playing...
"The more Poser improves, the more I'm inclined to think that we're gonna need to revisit the materials of the old products and revamp them to deal with the state of things."
Yeah, I'm slowly going through some of mine as well.
bagginsbill posted Fri, 07 October 2011 at 7:34 PM
I'm still waiting for answers to my questions. Been too busy to deal with this, and hoping the people involved would respond with data.
I'm not defensive, but I know how kawecki behaves and I know what happens in this forum when somebody, confused by incomplete knowledge, starts a showdown with me, about the f***ing math.
Argue whatever you like, the math does not lie. I didn't invent the math. The math is not my baby. I don't care if you don't believe in the math, either. All I care about is you don't leave totally false statements to lay about and trip up other readers trying to understand the universe.
Brewgirlca, we need to know what is the gamma in your scene. I suggested a scene with known things that we share. You can't share that with me. Yes you have render gamma = 1. That does not mean that gamma = 1 throughout your system.
What is the gamma of the color maps? What are the contents of the shaders? What if you have bought shaders that were built by people who used my VSS and those shaders happen to have shader GC? How would you know what the complete gamma is through those shaders if you don't look?
kawecki posted Fri, 07 October 2011 at 8:18 PM
Quote - I'm not defensive, but I know how kawecki behaves and I know what happens in this forum when somebody, confused by incomplete knowledge, starts a showdown with me, about the f***ing math.
If you want to learn something about cathode ray tubes (CRT) I recomend you the book "Cathode Arcs" by Andre Anders. Is good to read some serious technical books instead of repeating what someone put in some site in the internet icluding Wikipedia, even has its merits, is only one more site where anyone can write what he wants. And if maths are not your baby is good to learn them too, because without maths you go nowhere in technical subjects.
kawecki posted Fri, 07 October 2011 at 9:16 PM
As the gamma correction has its origen in the non-linear characteristics of the cathode ray tube, here is the transfer function of a typical tube. Find the value of gamma by yourself
kawecki posted Fri, 07 October 2011 at 9:17 PM
And the theorical value, as you can see the gamma value is 1.5
FightingWolf posted Fri, 07 October 2011 at 9:23 PM
Quote - Brewgirlca, we need to know what is the gamma in your scene. I suggested a scene with known things that we share. You can't share that with me. Yes you have render gamma = 1. That does not mean that gamma = 1 throughout your system. What is the gamma of the color maps? What are the contents of the shaders? What if you have bought shaders that were built by people who used my VSS and those shaders happen to have shader GC?
I agree with this 100% especially if Brewgirlca wants to improve the rendering issues that were mentioned. My guess is that Brewgirlca may not know where to go to find the necessary information.  For me personally, I would like to know.  Will the Image Gamma show information for the shaders or is that something that I would need to look for in the advance settings of the Material Room?  I can only guess that it would be in the Advance settings of the Material room.
RodS posted Fri, 07 October 2011 at 9:27 PM
BB, when you refer to the 'gamma of the scene' I'm not  quite sure exactly what you mean. I'm trying to understand all this as I'm fascinated by it. And understanding it can only help to create better art.
In looking over some of my scenes in the mat room, I'm not finding any gamma references anywhere . I did a bit of exploring, and found you can add gamma to a color map through NEW NODE>MATH>GAMMA. Is this what you are referring to?
Still learning this stuff, so just point me in the right direction - no need to rewrite something you've already explained..
I did a bit of playing earlier with the gamma setting in the render setting. I'll post my results just for grins...
RodS posted Fri, 07 October 2011 at 9:29 PM
Gamma at the default of 2.2... Poser Pro 2012, of course :-)
RodS posted Fri, 07 October 2011 at 9:30 PM
And 1.5 (just for the heck of it..)
RodS posted Fri, 07 October 2011 at 9:31 PM
Gamma 1.0...
RodS posted Fri, 07 October 2011 at 9:32 PM
Gamma 0.0 (actually 0.02)....
RodS posted Fri, 07 October 2011 at 9:34 PM
And Gamma off.
Clearly there's something else at play here...
If nothing else, it's given me some interesting ideas. :-)
brewgirlca posted Fri, 07 October 2011 at 9:35 PM
I don't answer questions from people on my free time, no matter how smart they are, who use F words and xxx to address people who might challenge their authority. If I acted over the top like that when junior scientists questioned my academic integrity I would get such a smack down from up the line.
You feel you have to act like that, fine. This sandbox is all yours. I've got the results I need from other commentators on the thread and from friends in the community. I am done here. You guys are more than welcome to keep playing with this string.
RodS posted Fri, 07 October 2011 at 9:35 PM
Render settings...
The only thing that was changed are the gamma settings. I did not use IDL.
RodS posted Fri, 07 October 2011 at 9:36 PM
And finally, my lighting setup. 2 spots; front and rear, 2 infinites; front and above.
FightingWolf posted Fri, 07 October 2011 at 11:11 PM
Quote - Gamma 0.0 (actually 0.02)....
I actually wrote about this on my site. This will cover why your character has a sun burn when you lower gamma. The burn is from your materials already having gamma settings.  I guess you can say "normally" you would want to make sure that none of your materials have gamma applied to them.  That way, when you render with a gamma correction of 1, then it will render as if gamma correction was not checked, But if your character materials already has gamma applied to it then the Gamma Correction in the render settings will be applied to the gamma that is already in the material.
The Gamma Correction setting in the rendering setting isn't the actual gamma.  It's the correction of Gamma. Or in some cases anti-gamma.  Baggins Bill can explain it better than I can.  I can only tell you how I use it in my art.
If you increase the gamma correction in the materials then the colors will become darker sort of like a burn effect.  If you balance it just right then you'll be able to actually enhance some older character skin materials.  The trick is to set the material's gamma at 2.2 with the exception of transparencies and then use Gamma Correction in the rendering setting to fine tune the amount of gamma that will be applied to the render. The benefit of using the Gamma Correction is that you don't have to go back and forth to change the gamma on all of the materials.  Just use the Gamma Correction .
In my case the amount of gamma that a person would use is up to the personal tastes and the look that you are trying to accomplished.  For me I pretty much abuse gamma correction and rarely go by the book on it.
RodS posted Fri, 07 October 2011 at 11:20 PM
Hey, thanks, FightingWolf! I definitely need to look around on your site! :-D
FightingWolf posted Fri, 07 October 2011 at 11:26 PM
Quote - Render settings...
Poser has 2 and probably more than two places where gamma can be changed.  The Gamma Correction in the render settings is not the actuall gamma setting.  Think of Gamma Correction as the setting that you use to add more or less Gamma to what is already there.
The best way to understand this, if you have Poser Pro 2012 (not sure if it's in Poser 9), is to go to Scripts -> Partners -> Image Gamma.  This will show you the gamma that the materials already have.  Chaning the Gamma Correction settings will either add to or decrease what is already there.  For example.  If the Gamma on the material is 2.2 and the Gamma Correction in the render settings is 1.5.  Then you have to combine (take into account) the 2.2 gamma that is already on the material with the 1.5 additional Gamma that was applied.  Don't ask me to explain the math.  I just know what happens when it's done.
The same Gamma Correction setting will produce different results based on the gamma setting that is already applied to the materials.  If you are getting image burns when you render at a Gamma Correction = 1 then it's because there is gamma in your materials.
RodS posted Fri, 07 October 2011 at 11:40 PM
OK - that explains a lot, and clears up some of the mental fog (lol).
The more I play with this stuff, the more I realize how much I don't know.. But you've cleared up a lot, my friend! Thanks!
